84 gsl, no start..
Old Jan 7, 2004 | 07:58 PM
CARLiTO_'s Avatar
84 gsl, no start..
I bought my car about 2 months ago, that was the last time i drove it. Did an oil change on it today. After, i went to start it and it would crank but not turn on. After about 10 minutes, i tried again and this time it would not even crank. Only the radio and dash light came on. I tried jumping it but same thing, anyone have any ideas?
It's all stock..
Old Jan 7, 2004 | 08:01 PM
Steve Shulz's Avatar
Do you get a click click? Probably your starter. You could try removing your bat terminals clean and reinstall.
Old Jan 7, 2004 | 08:49 PM
CARLiTO_'s Avatar
i checked for the clicks, no clicks..
Old Jan 7, 2004 | 09:31 PM
wwilliam54's Avatar
it WILL run
check the cables
Old Jan 7, 2004 | 09:35 PM
CARLiTO_'s Avatar
the batter terminals?
Old Jan 8, 2004 | 07:57 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
hey, the -SE you just gave me is doing this too! maybe we can figure it out together. I'd put jumper cables on it and let it sit for like 20 minutes... THEN try to start. It really sounds like your battery is just about dead.
Old Jan 8, 2004 | 08:05 AM
To verify your battery, remove the terminals and hook up your jumper cables directly to your terminal cables you just removed. Check your fuseable links and dash fuse too.
Old Jan 8, 2004 | 08:06 AM
anthrax's Avatar
Heck Yes!
Man I have a similar problem with my '84 GSL.
I have to crank and crank to get it to start, but my problem, the best I can figure it, is if the car sits for any length of time, is the the feul is draining out of the carb when the car sits for to long.
I have to put jumper cables on to start it or the battery will go dead.
So there is another possiblity
good luck
anthrax
Old Jan 8, 2004 | 08:32 AM
red13brx7's Avatar
I would let the battery charge over night and then try to start it. Do the stereo lights go dead when you try to crank on it? It could also be the switch.
Old Jan 8, 2004 | 12:02 PM
GavinJuice's Avatar
Leave A Message
Could be your alternator, also check all of your grounds. I dont think most people realize how vital a good ground it. If your ground to your battery is shot, try bypassing it with your jumper cable to try and pinpoint your problem. CHECK YOUR GROUNDS!
Old Jan 8, 2004 | 12:10 PM
slashdawg00110's Avatar
RTFFAQ
All good ideas above. But I'd also suggest looking at the mother of all no-start threads in the FAQ section. It's very helpful.
Try what's in there. If it doesn't work, let us know and we'll suggest some other things to try.
Old Jan 8, 2004 | 01:03 PM
faye x7's Avatar
brilliantly stupid
Engine could probably be flooded to by now.
NickNac113
13
Oct 1, 2015 09:25 PM
