Stereo Wires.......
Old Oct 14, 2001 | 06:32 PM
SpYdEr's Avatar
Question Stereo Wires.......
Im trying to install my own Kenwood head unit.....well it's normally quite easy in any car, except for this one.
I have a 89 Turbo II which I think came with a stock CD/Tape/EQ combo? or something like that. There is like 20+ wires back there, where there is normally about 10...and to top it off, they aren't the standard color most stereo wires are.
Basically, anyone have a diagram or list of which color wires are which? I have the speakers hooked up for sure, but I can't figgure out which is the ground (normally black), the power (normally red) or the cont. (normally yellow). Naturally the power antenna is messed up so Im not gonna worry about that, radio in alaska is crap anyhow
Any help is appreciated, thanks!
Old Oct 14, 2001 | 06:54 PM
Sniper_X's Avatar
Is the factory harness already cut?
DONT CUT THAT HARNESS!!!!
Go get a $5 adapter kit from Best Buy!!!!!
this works fine.
Also, I get the adapters for the factory speaker harness too!
Its worth it when you have to remove any of the parts!!!!
Otherwise, hmmm. I dont have the diagram handy.
try the factory manual at this link.
Old Oct 14, 2001 | 06:58 PM
SpYdEr's Avatar
Ha!
Yeah, I that would have been the easy way, but whoever had the car before me must have put in their own stereo and cut the harness' off......so, I have a pile of wires
Im downloading the wire diagrams now, hopefully they will help, but if they are like the usual ones, I doubt it hehe.
Thanks though Sniper.
Old Oct 14, 2001 | 07:02 PM
Sniper_X's Avatar
Sorry.
they changed the page.
When links fail like that, you should go to the main page by trying the main address (knocking off the part with slashes and navigating manually to the intended page.)
http://www.iluvmyrx7.com/Technical_I...ice_manual.htm
Here, i did it above.
Old Oct 14, 2001 | 07:03 PM
SpYdEr's Avatar
Hehe, I did that...just re-edited my post
Old Oct 15, 2001 | 04:54 PM
SpYdEr's Avatar
Anyone?
No one else has installed their own deck and not had the wire harness' be there? Someone has got to know which wires are which heh, please let me know if you do know which are which
Old Oct 15, 2001 | 05:22 PM
Sniper_X's Avatar
You know, with a volt meter you can tell what it what.
and speakers can be done with a AA battery.
In that order.
Its easy.
I can do it in 15 - 20 minutes.
Old Oct 15, 2001 | 07:14 PM
ShadowClown's Avatar
just make up a test light, a 12v light bulb with wire soldered to each end, ground 1 then poke around to find a positive and make the bulb go. thats ur cont, then turn the ignition on and find the ignition power.
TeamRuffRacing
Sep 30, 2015 08:13 PM
betes
Sep 27, 2015 08:25 AM
Captain Hook
Sep 22, 2015 01:12 PM
