2GCDFIS vs. DLIDFIS
Old Jan 2, 2004 | 05:52 PM
wwilliam54's Avatar
it WILL run
2GCDFIS vs. DLIDFIS
Im wondering about the advantages of both
I know that the 2GCDFIS is generally cheaper, but in the paul yaw ignition article, I remeber reading how the stock 2nd gen coils have a prob with providing good spark at higher rpm's, cuaseing high rpm breakup
does DLIDFIS have a simialar prob, or does it supercede the 2GCDFIS in every way exept cost?
Old Jan 2, 2004 | 07:45 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
I'm not sure than any qualitative tests between the two have been conducted. I would think that DLIDFIS would have a decisive advantage if high quality aftermarket coils were used, rather than the stock Diamond coils. I don't think that the DLIDFIS system has any high RPM problems, certainly none that Jeff20B has found. My car was more willing to rev to redline with the new ignition system installed, so I don't think there is any limitation there.
Old Jan 2, 2004 | 07:53 PM
wwilliam54's Avatar
it WILL run
im probly going with jeff20b's method with some blaster coils and gm igniters
just wanting to see if i should rethink it
Old Jan 2, 2004 | 07:54 PM
inittab's Avatar
I read your email
My 2GCDFIS runs great in the high rpm's. Much better than my stock setup.
Old Jan 2, 2004 | 10:31 PM
specRX7_22's Avatar
what exactly is 2GCDFIS and DLIDFIS?
Old Jan 3, 2004 | 02:00 AM
Jeff20B's Avatar
Lapping = Fapping
Check the FAQ.
Yeah, I've never had any troubles at high RPM with DLIDFIS. Since each plug gets its own coil and ignitor, you can't go wrong.
Old Jan 3, 2004 | 02:40 AM
abeomid's Avatar
well I revved up my car bunch of time to over 9000RPM by "mistake" on track w/ DLIDFIS before and no problems with ignition.
Old Jan 3, 2004 | 10:30 AM
rotarygod's Avatar
Rotors still spinning
I have the MSD direct fire conversion and have never had any issues with it at high rpms. It is much smoother than stock.
Old Jan 3, 2004 | 12:50 PM
wwilliam54's Avatar
it WILL run
oh defianlty
MSD is the best, but far to expensive for me
Old Jan 3, 2004 | 01:25 PM
rotarygod's Avatar
I am using 2nd gen leading coils. They work great.
Old Jan 3, 2004 | 09:09 PM
Metallic_rock's Avatar
Ride 'n Style
the few times I have gotten up to 7 k with my 2G DFIS, I have had no problems whatsoever. I have done both methods and prefer the 2G setup becuase it is so much simpler. There is less crap in your engine bay to mess with.
It's all personal preference. If you have quesitons on either method, I'm sure any one of us who have done the mod will give you help either way.
Old Jan 4, 2004 | 12:04 AM
Sk8r_dude's Avatar
Zoom - Zoom...
anyone have pics of a 2nd gen system?
Old Jan 4, 2004 | 01:16 AM
Ride 'n Style
https://www.rx7club.com/showthread.p...hreadid=243350
note: that was in the FAQ sticky page.
Old Jan 4, 2004 | 01:12 PM
Sk8r_dude's Avatar
Zoom - Zoom...
i was looking for a pic of one using the 2nd gen distributor like thing
Old Jan 4, 2004 | 01:53 PM
Ride 'n Style
ahh... that's not possible unless you swap over the whole computer and everything. (as far as I know) The impulses from the crank angle sensor can not be interpreted by an ignitor therefore can't be used without the comp.
Old Jan 4, 2004 | 05:07 PM
slashdawg00110's Avatar
RTFFAQ
No experience with DLIDFIS, but I did the 2nd gen leading coil thing last week and have been very happy. I spent $28 on ebay to get the coil. Spent another couple bucks on electrical connectors and self-tapping screws. It was easy and cheap and works.
Old Jan 4, 2004 | 05:49 PM
Jeff20B's Avatar
Lapping = Fapping
I'll hook a 2nd gen leading coil to an MSD 6AL some day. It'll go on a half bridgeport engine so I won't overrev it. I also have a 2nd gen trailing coil and a leading ignitor. I think I'll hook them to trailing and see if it makes a difference.
I'm running low on 1st gen ignitors and distributors around here, what with all the engines I've been getting to run lately.
GKW
Sep 28, 2015 04:34 PM
