Air pump/ACV removal
Old Jan 2, 2004 | 03:32 PM
j-spec_wannabe's Avatar
Rotary []D[][\/][]D
If i remove my Air Pump, and purchased a block off plate for my ACV would my car still run the same?
Old Jan 2, 2004 | 05:49 PM
Rotary []D[][\/][]D
I have a 1980 SA22C if that helps
Old Jan 2, 2004 | 05:54 PM
wwilliam54's Avatar
it WILL run
mine backfires less
Old Jan 2, 2004 | 07:40 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
Your car won't run any different really, but you can't get rid of the airpump/ACV without getting rid of your Thermal Reactor and installing a header system. It can overheat and damage apex seals if they happen to end up near the exhaust ports, not to mention that your car will backfire like mad if you delete your airpump and keep your TR. Trust me, I know. The short drive from my house to the garage that installed my header was interesting to say the least.
Old Jan 3, 2004 | 12:11 AM
Rotary []D[][\/][]D
damn thats good to know, i better get on buying a header, are you sure about that damaging my apex seals
Old Jan 3, 2004 | 01:25 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
It is a possibility, yes.
The air pump supplies cooling air to the thermal reactor. Without this cooling air, the thermal reactor's inner chamber can overheat. When the motor is shut down, the heat can transfer back into the motor possibly damaging an apex seal spring if an apex seal has "parked" itself in the exhaust port window.
ZacMan
Sep 19, 2015 09:20 PM
risingsunroof82
Sep 7, 2015 01:11 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
Frisky Arab
Sep 4, 2015 06:17 PM
