Re-center steering wheel ?
Old Dec 28, 2003 | 06:39 PM
Fred Sickert's Avatar
Anyone know the easiest way to re-center the steering wheel? My front end is a little screwed up and the only way to get the toe right was to have the steering wheel turned slightly left.
Old Dec 28, 2003 | 06:44 PM
Sesshoumaru's Avatar
Tenseiga
alignment
Old Dec 28, 2003 | 07:16 PM
This is after the alignment.
Old Dec 28, 2003 | 07:35 PM
Tenseiga
sometimes the mechanic forgets about the steering wheel
had a friend that they couldn't center due to lowering the car and the tie rod end running out of threads (need to have like 1/3 of them left or something). It was only slightly turned.
i would go back and ask.
Old Dec 28, 2003 | 07:43 PM
Yeah, the tie rod ran out of threads. The mechanic knew. I figure I can just rotate one of the mounts leading up to the steering wheel a bit. I am wondering if there is an easy way to do this.
Old Dec 28, 2003 | 07:54 PM
Tenseiga
i would take the steering wheel off and roate it.
u can rotate the linkage like u said but a bit more difficutl i think. they are usually a real pain.
Old Dec 28, 2003 | 08:22 PM
areXseven's Avatar
il Cosa Nostra e vivo!!
From: Dove le cose sono fatte il vecchio moda il senso
I don't know if this will work with our beloved FD, but, I once had a 69 Camaro that needed the steering wheel centered. A friend of mine did it simply by loosening the "steering box" bolt, which loosened the steering wheel column, then I held the steering wheel in the centered position as he tightened the steering box bolt. Presto. Took most of 5 minutes.
Once again,..I don't know if this procedure will work with the FD. Good Luck.
Old Dec 28, 2003 | 09:16 PM
clayne's Avatar
PV = nRT
Fred,
Fix the front-end problem first.
If it's impossible to fix, pull the airbag and move the wheel a spline over.
Old Dec 28, 2003 | 09:30 PM
crazyrx7's Avatar
Big Daddy!!!
You shouldn't have a problem aligning your car. My car is really low and the steering wheel is dead center and the guy didn't have any problems doing it. He never mentioned that he ran out of thread either. Go get it realigned.
R.K.
Old Dec 28, 2003 | 09:39 PM
Tenseiga
he said the tie rod ran out of threads............
if u alter the spline i wonder if it'll affect teh pwr steering sensors.
it might be done at the rac. I never bothered to look (i took mine out)
somethign to consider
Old Dec 28, 2003 | 09:46 PM
clayne's Avatar
PV = nRT
There is no spline altering occuring. We're talking about repositioning the steering wheel on the splines that come into the driver's area to mount the steering wheel on the upper shaft.
You could pull the wheel off and mount it upside down if you wanted - the rack will have no idea.
Old Dec 28, 2003 | 09:48 PM
Tenseiga
i was talking spline
steering wheel like i said earlier is np
Old Dec 28, 2003 | 11:56 PM
That did the trick ! Two clicks right. This forum rules !
Old Dec 29, 2003 | 12:32 AM
Tenseiga
:0
rock on man
(i'm pretty drunk)
Snoopy FD
Dec 8, 2015 01:45 PM
breakfast
Sep 1, 2015 11:02 PM
