subwoofer placement
Old Dec 28, 2003 | 02:23 AM
rx78788's Avatar
subwoofer placement
does anybody know if putting a subwoofer in the bin behind the seats sounds ok, or should i just buy a box.
Old Dec 28, 2003 | 04:57 AM
ioTus's Avatar
'84 5-letter
Personnaly, i would just buy a box!! You want a square box, as far back in the car as you can, firing directly up to hit the rear window.
I have never heard a ride w/ them in the pass bins, but both my current setup and previous setup (in my old 12a blackie) had a box. i loved them. And i just have a shitty box, not firing in the right direction. yeah. anywyas.
Ur in washington! we should get together some time.
Old Dec 28, 2003 | 06:47 AM
Lee Lyons's Avatar
speaker layout
check it out...but you'd need alot of room!!
Old Dec 28, 2003 | 06:48 AM
Lee Lyons's Avatar
s*%$ didn't work oh well!! I had a cool pic anyway.
Old Dec 28, 2003 | 08:16 AM
John64's Avatar
What?
Enclosure
My enclosure turned out awesome, but it was alot of work to do. If you've never done fiberglass it will be a long project. Take a look at my web page. I hit 134db with 600 watts. You need a sub that can fit in small spaces, around .64cuft.
John
Old Dec 28, 2003 | 08:51 AM
Steve Shulz's Avatar
Placement of subs will totally depend on you. I had a box that fired up to the glass, now I have a box that sits right behind the seats and fires straight back, and it hits hard (very little room for anything else though). Base is omni directional so placement is like the butt dyno, interprited by you. The further you are away from the source the smoother it will sound. I would like to hear how john64's sound, that just looks too nice.
Old Dec 28, 2003 | 09:02 AM
BigJim's Avatar
trainwreck
What about putting Trebel speakers in the bins, and subs in the back like you 2 have. I dont like the all bass trend. I like to hear the lyrics nad guitar.
Old Dec 28, 2003 | 10:35 AM
jbcobra's Avatar
There's a nice article on the MazSpeed site that has dimensions for building a hidden sub box for the storage bins. I haven't tired it yet but it seems like a good option if you don't want to fill up the hatch with speakers. I also thought about trying a bazooka style tube sub in one of the bins. Here's a link to the MazSpeed page
Old Dec 28, 2003 | 11:23 AM
Directfreak's Avatar
I am a Jeeper Now.
Here is a really good thread with info.
Old Dec 28, 2003 | 11:27 AM
ioTus's Avatar
'84 5-letter
You wouldn't want to place treble spekaers (tweaters) out of direct line of sight. Otherwise its just counter productive and a waste of money (treble doesnt pass thru objects as well as bass does), and as mentioned before, you would want the bass wave to be as long as possible before it reaches you.
this is my personal preference.
Old Dec 28, 2003 | 12:01 PM
redrx's Avatar
I have 6/9's in the bins behind seats, and a 10" alpine sub in a truck box about 6" back from my seat, and small speakers up front. It sounds good, but I could use some more treble up front
Old Dec 28, 2003 | 12:40 PM
I am a Jeeper Now.
This is what I have been planning for over 2 years. Other "things" have been more important though.
I will likely have to re-design it now because of my cage though.
Old Dec 28, 2003 | 02:55 PM
Forgie's Avatar
I have my 6x9s in the bins and my subs firing off the back window. sounds awesome. only thing you need to worry about is the height of the box. I had to lay my box on it's back because it was blocking my sight out the rear window.
Old Dec 28, 2003 | 05:03 PM
Thumbs up Subwoofer install
If you are still looking for 'Sub'suggestions I just completed a really neat installation in my first Gen. Purchased the smaller 'cannon' style Bazooka sub woofer with built in amp. I removed the bin behind the passanger seat and cut an 8"hole in outside end-facing out as directions suggested then cut a hole in the other end so I could access controles on subwoofer-I insulated below bin and added cushion between cannon and bottom of bin so it fit snugly. Then I reinstalled bin and removed drivers side and accessed all the wiring from there. I could even lock the bin after it was reinstalled and best of all it is invisible. I'm sure there are ways to add more base, but when this is combined with 4 really nice infinity speakers installed in stock locations it gives me very good balanced sound- I just don't care for giant speakers in the back of the car asking to be stolen! and it will still shake the car.
Old Dec 29, 2003 | 12:25 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
i have a set of 8" l7 kicker solo's in the far back of my 83... they sit behind the rear carpet and against the tail lights.... stealth and they hit pleanty hard
Old Dec 29, 2003 | 02:19 AM
cdrad51's Avatar
Lorem ipsum dolor sit ame
I also have 4 Infinity speakers in stock locations, and 10" woofer-passive-radiator with a built in 200 watt amp (Infinity Bass Link) in the trunk space, facing up, next to the passanger side bin. Not invisible, but pretty compact and it delivers.
Old Dec 29, 2003 | 05:42 PM
yayo420's Avatar
I have 2 solobaric 12's in a teeny *** box w/ the speakers firing back and w/ the box pushed all the way up against the glass......Ive tried just about every position for the subs and this seems to be the best.....BTW David, your 8's aint ****
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Shainiac
Jul 17, 2019 02:20 PM
