Turbo Disassembly
Old Dec 25, 2003 | 05:26 PM
rx7fntc's Avatar
Turbo Disassembly
I tried searching but have not found a good site or thread that gives detailed steps to follow when completely disassembling them. I need to remove the exhaust housing on the primary turbo so I can enlarge the wastegate. I want to have it removed so I do not run the risk of getting shavings stuck causing premature turbo failure. So far I have the turbos separated and shaft bolt removed on the turbo. On the TD04's I had rebuilt, I just tapped the shaft and exhaust turbine out... Do I do the same with these? After shaft is out, will housing come off? (I removed 6 bolts and plates that seems to keep housing in place). Thanks for helping me out!
Old Dec 26, 2003 | 12:32 AM
poss's Avatar
Slower Traffic Keep Right
you just pull the cartridge off the exhaust housing. You have already removed the appropriate bolts and straps. sometimes it takes a little...persuasion
You didn't need to take the compressor nut off, so I would recommend putting that back on in order to keep your turbos from coming out of balance.
ChrisRX8PR
Aug 21, 2015 01:56 PM
BLK 93
Aug 19, 2015 03:47 AM
Marty RE
Aug 13, 2015 11:19 AM
