Sponsored by: CARiD
catalylic convertor installation
Old Dec 22, 2003 | 11:29 AM
sj_rx7nut's Avatar
My 91 convertible needs a cat replacement.
Is this a simple job assuming the nuts and bolts aren't badly rusted?
Can I get the the manifold bolts with the car on jack stands, or does it need to be on a lift?
Do I need any special tools or will basic metric sockets work?
I'm looking a direct fit, one piece to replace all OEMs.
I found 2, one from Walker (Advanced Auto) and one from summitracing.com, both are about $165. Any other suggestions?
Old Dec 25, 2003 | 12:41 AM
astrochild7's Avatar
controlled kaos
look on www.rx7.com they have a direct replacment by bonez. You can't buy just any old "Cat" for the rotary engine due to the higher exhaust temps and volume/flow... Do not buy a generic replacment cat or you be buying another one soon. the bonez cat will give you a little more hp also......
Old Dec 25, 2003 | 01:20 AM
wwilliam54's Avatar
it WILL run
get a cat replacement pipe and a cheap generic cat
just use the cheap one on test day, otherwise use the replacement pipe
Old Dec 25, 2003 | 07:28 AM
sj_rx7nut's Avatar
Thanks for ther replys. I'm a new rx7 owner and have a lot to learn.
Old Dec 25, 2003 | 09:34 AM
sj_rx7nut's Avatar
I also have I question about tire size posted, it did not get any replies. Is there any advantage to using 215/60-15, instead of the stock 205/60-15
Old Jan 4, 2004 | 12:39 AM
^traction is about the only advantage, lol
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
