I Think I need a new engine... Help!
Old Dec 22, 2003 | 10:45 AM
Exclamation I Think I need a new engine... Help!
Hi everyone,
I have a 93' touring that I have been chasing a cooling problem for about 3 months. Coolant is being pushed out the resivior all the time. I have replaced the thermostat, water pump, radiator, Fan relays, Water pump thermo-switch. Nothing. Still does it. Fans are running. I think my O-rings are shot, I cant come up with anything else that could be it. Any help would be appriciated. If I need to get a new engine, any suggestions as to which place I should get it from? I'm located in CT.
Thanks,
Jason Dean
Old Dec 22, 2003 | 11:40 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
Do the champaign bubble test. If there are bubbles then your coolant seals are gone. If not then you may need to replace the preasure cap.
Old Dec 22, 2003 | 12:33 PM
Slam Pig
pressure cap fixed me....jack one off someone elses car before you buy one.....the one of my mom moms acura worked just fine
Old Dec 23, 2003 | 08:50 AM
champange bubble test?
What is the champange bubble test?
Old Dec 23, 2003 | 08:51 AM
I replaced the capwhen I replaced the water pump already. I do smell a sweet smell in the exhaust.
Old Dec 23, 2003 | 08:52 AM
with the cooland pressure cap off... you see tiny little champagne like bubbles......
Old Dec 23, 2003 | 03:22 PM
jpandes's Avatar
the engine should be running when you do this.
Old Dec 23, 2003 | 08:41 PM
impactwrench's Avatar
pettit racing.............changed out mine in june. stop messin with testin. you've been readin the forum. i too, hoped that my cooling problems were some quik fix thing, but we all know better. start pullin it and get it over with
Old Dec 23, 2003 | 09:06 PM
I have the same problem(o-ring failure) I'm going to have Atkins Rotary here in WA state build my dream engine. They sell videos on removing the engine and getting it running. Do the labor yourself save the money for upgrades. Good luck!
Old Dec 23, 2003 | 09:18 PM
DaedelGT's Avatar
Uber Newb.
impactwrench, that's not helping at all.
Old Dec 24, 2003 | 10:02 AM
ok I guess i will just order a new engine and swap it out, wont be very difficult I think. thanks guys.
Chiaszy
Sep 23, 2015 01:43 PM
Enthu
18
Oct 6, 2003 10:56 AM
Gregs
36
Sep 28, 2003 07:05 PM
WanKeL FD RX-7
Sep 9, 2003 07:49 PM
HoNdA KiLLeR 212
Sep 6, 2003 11:57 PM
