Disconnecting airbag to remove steering wheel?
Old Dec 20, 2003 | 04:04 PM
jmo87's Avatar
Hey guys, I am replacing my stock wheel with the efini wheel. Do I need to disconnect the airbag some how befoire removing the wheel? I dont want the thing going off on me. If so, tell me how. Thanks!
Old Dec 20, 2003 | 04:26 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Take off the negative, remove the rubber caps on the steering wheel.. un bolt so that the airbag is detached..
Unplug the airbag..
now just remove the steering wheel.. all the lines.. and put your efini.. but you know.. your engine or airbag light will come on..
hope this helps
Old Dec 20, 2003 | 07:56 PM
HeatTreated's Avatar
Hi Powr FD's
Can you use the 1/2ohm resisters like done when blocking off actuators?
I was interested in an upgraded wheel also, but didnt want the light on.
Old Dec 21, 2003 | 09:39 AM
jmo87's Avatar
And what about re-running the horn wire? And should I just cut off the airbag wire? Any suggestions? On the stock wheel the horn and airbag wires come through the bottom of the wheel, and on the efini wheel the horn line runs through the top of it. Just tryin to figure out how to run it so I still get full rotation of the wheel. Also tryin to be able to maintain the use of my cruise control. Thanks again.
Old Dec 21, 2003 | 10:01 AM
Want2race's Avatar
Bigger and better things
CAREFUL!
Disconnect the battery and leave it for an hour.. if the airbag control unit goes off and your woring on it; it often breaks your neck.. So carful1
Old Dec 21, 2003 | 01:41 PM
jmo87's Avatar
...i already have the stock wheel off
Old Dec 21, 2003 | 01:54 PM
InsaneGideon's Avatar
Still on 1st engine
After you disconnect the battery, step on the brake pedal for a second. The brake lights will use up any left-over charge in the system.
The airbag diagnostic module will freak out about an open circuit if you cut the wires. Use a resistor. Not having removed an airbag myself, I couldn't tell you what resistance, but I'm sure someone will eventually respond.
Old Dec 22, 2003 | 11:33 AM
jmo87's Avatar
Come on guys, I know some of you have replaced the stock wheel with aftermarket ones. How did you wire the horn?
Old Jan 12, 2004 | 02:29 PM
mrb63083's Avatar
Bumpin for a friend...
Old May 2, 2004 | 08:33 PM
austinsFD's Avatar
Ahhhh Motherland!
good luck
Old May 2, 2004 | 08:37 PM
austinsFD's Avatar
Ahhhh Motherland!
good luck
Old May 2, 2004 | 08:38 PM
austinsFD's Avatar
Ahhhh Motherland!
good luck
Th0m4s
Feb 26, 2019 02:04 AM
