air pump operated GSL-SE 6th ports, how do I do it?
Old Dec 19, 2003 | 08:21 PM
Barwick's Avatar
SCCA Rookie
Anyone have a *good* writeup on it? I've searched and searched and soyched and soyched and came up with very little to nothing.
Basically here's what I've got:
  • Take the air pump outlet hose, run it to a 3-way tee
  • Connect one side of tee to air pump outlet
  • Connect another side of tee to (about a foot?) of ruber hose
  • Connect the last part (in whatever manner of sizing necessary) to the 5th and 6th port actuators
  • Take the spare tubing mentioned earlier and connect it to a bleed valve, trial setup the bleed valve and go for a spin, see where they open up, adjust accordingly
If that's seriously all that needs to be done, then "yay me!! I just made a writeup"... but I'm not so sure.
Anyone any ideas/comments?
Old Dec 19, 2003 | 09:37 PM
RacerX7fb's Avatar
paradox
http://www.rotaryresurrection.com/airpump.html
Old Dec 19, 2003 | 09:57 PM
Barwick's Avatar
SCCA Rookie
excellent
Old Dec 20, 2003 | 08:40 AM
Steve Shulz's Avatar
Post a follow up when your done, let us know how it worked out. Very interesting concept.
Old Dec 20, 2003 | 01:47 PM
Barwick's Avatar
SCCA Rookie
Got the parts, I'm going to see how it works.. I kinda stumbled upon the ones I needed at The Home Depot.. I was really surprised.. 4 parts from them (excluding hose clamps and such)..
So far I've got:
- Brass Ball Valve that fits the same size tubing as the airpump tubing
- 3-way brass "T" that fits same size tubing as airpump tubing (I believe it's 3/8 inside, I'll have to get the part number..)
- Brass 3/8 (I think) male down to 1/4 female screw-in reducer
- Brass 1/4 male to 1/8 barb nipple.
And I'm spent... I'll let you know how it works
Old Dec 20, 2003 | 06:05 PM
Barwick's Avatar
SCCA Rookie
gwaa... I have it working but one of the ports sticks fully open once it opens.. *sigh*
So I've got it set to just open full out at nearly idle so they both open real low and don't lean out the fully open cylinder because the other one isn't fully open (as mentioned before).
But it does seem to work.
Old Dec 20, 2003 | 11:30 PM
Chemical's Avatar
I just did this tonight too..
works like a charm, the adjustability is so precise too, I can make it open and close at nearly any RPM
Old Dec 21, 2003 | 02:18 PM
Barwick's Avatar
SCCA Rookie
cept its freaking LOUD
Old Dec 21, 2003 | 04:14 PM
Chemical's Avatar
Yup, i'm thinking about rigging up that 'muffler' that used to be attached to the ACV to the vent side of the Y valve to quiet it down a bit
Old Dec 21, 2003 | 04:19 PM
Forgie's Avatar
I did this a few weeks ago and I'm not sure that it's working. how do I know if the ports are opening or not?
Old Dec 21, 2003 | 05:26 PM
Chemical's Avatar
you can watch them while manually opening the throttle..
to adjust what rpm they open and close at its best to have a friend sitting in the car so he can see the tach
Old Dec 21, 2003 | 06:18 PM
RacerX7fb's Avatar
paradox
Lets see some pics of your progress guys
Old Dec 22, 2003 | 03:38 AM
Chemical's Avatar
I'll see what i can do about pics
Old Dec 22, 2003 | 01:45 PM
pics please,,,, cant wait to see em!
Old Dec 22, 2003 | 01:58 PM
Dcrasta's Avatar
That worked great for me also but then my AIR PUMP locked up . I now want to figure out a way to make them open and close without an air pump (Solinoid?)
Old Jan 27, 2004 | 07:09 PM
totallimmortal's Avatar
Is that thing Turbo?
if someone has p[ics please post i really want to do this but don't know what to do
Old Jan 28, 2004 | 06:39 AM
Yeah, we should have some pic on this, it would be cool to actually see it.
Old Feb 16, 2004 | 02:33 AM
Chemical's Avatar
Sorry it took so long, but heres the pic..
Old Feb 16, 2004 | 09:18 AM
Wow, now I know why your saying its so loud! If you got a hose and put on the end of your "pressure relief side to the tube that goes back to the cat (is see its open) it would quiet it down alot, also check that your check valve is really working too it may be coming back up, just get some 3/4" heater hose, thats what I used to bypass my ACV. Looks good though. Now I know another use for gardening equipment.
Old Feb 16, 2004 | 09:41 PM
Chemical's Avatar
Haha well actually i'm running RB Header + presilencer(no cat) and now that i've got the air pump mod I have no use for that tube. I've just procrastinated taking it off
Old Feb 16, 2004 | 09:48 PM
BigJim's Avatar
trainwreck
i thougth that check valve hooked onto the lower intake somewhere?
Old Feb 16, 2004 | 10:46 PM
Chemical's Avatar
The check valve is connected to the ACV if I recall..
Old Aug 28, 2007 | 08:02 PM
bugman1973's Avatar
advanced novice
Originally Posted by RacerX7fb
does anyone have a new link that works for this
Old Aug 28, 2007 | 10:04 PM
GavinJuice's Avatar
Leave A Message
i went to napa and scrounged through their wall of premolded rubber tubing. i found a perfect 180degree turn that i used from the "Y" to that muffler thingamabob. you couldn't hear the airpump anymore and worked like a charm. It had like a 3/4 ID that slipped over the hose barb from the brass Y.
Old Aug 29, 2007 | 05:21 AM
bugman1973's Avatar
advanced novice
well the thing is that i dont know how to do this at all. and wanted to get some step by step kind of thing.
