Add coolent light
Old Dec 19, 2003 | 05:37 PM
stock79's Avatar
Add coolent light
I flushed and refilled cooling system, using engine block drain. Also replaced temp sensor and radiator cap. Heater puts out lots of hot air, but add coolent light keeps coming on when I drive. It stays off in idle or if I rev it up while stationary. The level of coolent in the overflow tank never changes. What did I do wrong? This happened a few years ago and I corrected it with a new radiator cap.
Old Dec 19, 2003 | 06:52 PM
JIMMY54's Avatar
GSL-SE PRO
Did you make sure there aren't any large amount of air in the system?
Old Dec 19, 2003 | 07:49 PM
christaylor's Avatar
Also check to make sure your level sensor wire isn't fixing to break off. I've had two go bad and eventually break off the radiator. Took me a long time to figure out what the hell was going on, too.
Could also be that the sender is going bad. I've had that happen a number of times, too.
Old Dec 19, 2003 | 08:00 PM
g prime's Avatar
I have had that same problem to, that light hasn't gone off since I got my car. The connection was broke. I haven't overheating and the temp guage is still good.
"Warning lights can only be ignored so long, till you cover them with electrical tape."
Old Dec 19, 2003 | 09:35 PM
Kahren's Avatar
i am not a girl
please move this to the 2nd gen forum
Old Dec 19, 2003 | 09:39 PM
FD Racer's Avatar
sold the FD...kept the FB
why?
Old Dec 20, 2003 | 06:33 AM
Re: Add coolent light
Seeing as how his name is Stock 79, I assume he has a first gen...
Old Dec 20, 2003 | 07:07 AM
stock79's Avatar
Yes, it is a 1979 sa22c, no mods. Am going to replace overflow hose,it appears to be clogged. No fluid transfer from radiator to overflow tank.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
rx7shirley
Sep 2, 2015 02:11 PM
