Can I use a TII transmission with a NA rear end with a auto vert. driveshaft?
Old Dec 17, 2003 | 12:10 AM
JonEQuest's Avatar
Yes, that is my car
I heard that this combo allows a TII trans to be bolted into a NA car. Is it true, and if so how do you know.
John
Old Dec 17, 2003 | 12:38 AM
JonEQuest's Avatar
Yes, that is my car
bump
Old Dec 17, 2003 | 07:11 AM
Rotorific's Avatar
I dont know a damn thing
Yes it will work... you will also need a turbo size clutch/flywheel.
Old Dec 17, 2003 | 08:55 AM
lnbrown5981's Avatar
Just take the blue pill..
it will work but, i would recommend getting a custom driveshaft from mazdatrix or someone. i think they are like $242.00 us or something. they have replaceable u-joints, and unlike just using the auto d-shaft, which by the way will not go all the way into the tranny, will work perfectly. just call mazdatrix and see if they make a driveshaft with turbo front yoke, and n/a rear u-joint. shoud be no problem.
hth
lamar
Old Dec 17, 2003 | 09:00 AM
bt880720's Avatar
No. The auto drive shaft will not work. The T2 drive shaft will work if you re-drill the rear flange. Or you have to get a custom drive shaft. Mazdatrix does this like the guy above said.
Old Dec 17, 2003 | 10:05 AM
JonEQuest's Avatar
Yes, that is my car
Hmmm, have you ever redrilled a rear flange? I have dremel and If I work nice and slow I am sure I could do it nice and evenly.
John
Old Dec 17, 2003 | 10:18 AM
Kenteth's Avatar
Like Ghandi with a gun
I was just looking at the driveshafts from mazdatrix. They either would have them, or could fab one up for you for a faily decent price. And you'ld be able to change the ujoints after that too...
Old Dec 17, 2003 | 10:23 AM
Project84's Avatar
Open up! Search Warrant!
You can use a N/A flywheel with a turbo tranny. You cannot use a turbo flywheel with a N/A tranny case the turbo flywheel is too big around.
Old Dec 17, 2003 | 12:04 PM
Bukwild's Avatar
a dremel would take a while. Plug in drill would ease the process
Old Dec 17, 2003 | 05:02 PM
JonEQuest's Avatar
Yes, that is my car
well, yeah I guess I would do that first. But I could be pretty precise.
John
Old Dec 17, 2003 | 08:11 PM
Juan's Avatar
Im a tall midget.
I would take it to a machine shop and have them drill it for you. I would imagine that the driveshaft could be unbalanced if your holes werent evenly spaced out or if some were bigger than others.
I would use the auto driveshaft as a temp. solution until you have enough money for a good custom one.
Old Dec 17, 2003 | 09:01 PM
JonEQuest's Avatar
Yes, that is my car
I think that If I am carefull enough I could drill out the holes until they are just big enough to reach on all four corners, that should keep it balanced enough.
John
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
