Broken oil lines to carb!
Old Dec 13, 2003 | 03:34 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
OMFG!
I was doing a routine inspection in the engine bay today, when I take a look at both oil lines coming from the omp to the carb, and they're broken at the point where they go over the alternator. I've no idea how long they've been like that! by sheer luck I have been experimenting with some MMO added straight in the gas tank for a couple of weeks now, in addition (or so I thought) to what normal oil the omp supplies to the carb. I wonder what would have happenned otherwise. Got those fixed now, and just in case filled up the gas tank and didn't add any MMO this time. Well that was a easy oil leak to fix . How long would the engine run before having problems if there was no oil going into the rotors?
Old Dec 13, 2003 | 04:21 PM
mazdaverx713b's Avatar
Have RX-7, will restore
i have heard a rotary can only run for NO MORE than 15 mins with no oil cooler. imagine a minute or two with no oil
Old Dec 13, 2003 | 06:07 PM
Rx7carl's Avatar
Airflow is my life
It would just cause extra wear to the seals. It will run till it wears out. Not trying to be a smartass, just it will run for a while. Not like running without oil pressure. I once forget to hook the tubes back into the carb when I was doing some testing. Left them off for 3-4 days. Didnt affect the already crappy compression at all.
Old Dec 13, 2003 | 08:31 PM
sgieldon's Avatar
Call Ron at Pinnapple Racing.
He told me once that as long as the engine has been taken care of well over the past 15 to 20K miles it will not kill the seals to bad.
He did a rebuild back in March and the DumbF@#!$% i.e. customer ran with the lines disco'd for approx 10k without knowing that was the Dealer set it up because of an Oil Leak around the OMP.
Not that it would kill your Motor right a way, but not a good idea.
Face it Rotors are 2 stroke weither we like it or not.
As much time and$$$ we gots invested in these wonderful machines --Pre-Mix or OMP it's not worth the cost of short changing the Blood this concept has to work correctly.
Just a Sat Nite Babble
Steve
Old Dec 13, 2003 | 08:42 PM
jimmdog's Avatar
DUde Youre OK just repair the plastic hoses Sleeve them with some vacum hose and let it ride those engines can take some Skata! (greek for DO Do)
Old Dec 13, 2003 | 09:22 PM
brianw's Avatar
Mine has vacuum sleeves, works okay,leaks a tiny bit still. Im going to amke some steel or alum. ones one day. I promised Carl so I'd better get of my wallet and do it soon I guess. I hate to get puttting it off and yet I do.
Old Dec 13, 2003 | 09:53 PM
erick1120's Avatar
If you really want to replace them and make it look original you can always order them. I know you can get them from atkins and probably racing beat or mazdatrix. If not then just use some vacume line or small fuel line.
Old Dec 13, 2003 | 10:11 PM
brianw's Avatar
I want to replace all the lines with alum. I think I can make it much cleaner looking that way and I know how to anodize them myself.
Old Dec 14, 2003 | 02:30 AM
cdrad51's Avatar
that's precisely what I did.
Old Dec 14, 2003 | 10:00 AM
Directfreak's Avatar
I am a Jeeper Now.
I bought my new OMP lines from Mazda less than5 months ago, so they are still available
I have an idiot friend who runs her 1st gen without it. It's been 2.5 years..
FD7KiD
15
Feb 26, 2021 10:12 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
pzr2
Aug 15, 2015 08:29 PM
