Sponsored by: CARiD
engine timing for 90 n/a fc
Old Dec 6, 2003 | 12:15 PM
jorx7's Avatar
just put new motor in wit low miles new injectors, lines etc ,car holds idle is driveable but gets wacky around 5000rpm . exaust pressure is very hard , im not sure witch notch off of the main pulley i should mark up the first or second . i know how to line up the crankangle sensor , for timing it , but not sure on which mark first or second any help is much aprecciated ,or other info will be help full
Old Dec 6, 2003 | 09:29 PM
black_sunshine's Avatar
If by getting whacky at 5k, you mean it's hesitating ("bumping"), then I'd replace your fuel pump and filter ASAP.
As for the timing, turn the E-shaft until the TOP mark (YELLOW) is aligned with the timing marker. Then turn the CAS gear (with CAS removed) until the two dots allign. re-insert CAS. Typically, the CAS should be 1/4" - 3/8" clockwise FROM the bolt. This means, that if you're standing on the driver's side, you will have 1/4" - 3/8" on the LEFT side of the CAS guide.
If that doesn't fix it, then go through the entire fuel system check. You've most likely got a bad/weak pump (or may need it wired with a direct battery link via a relay) or a clogged filter. When in doubt, get an ohm-meter and check all the sensors (including the coil packs) and make certain your VDI and 6pi is working (put grease or paint on the shaft of the actuators; I forget weather they push or pull at the moment).
If it's still having troubles up high, do a thorough re-grounding of the ECU. https://www.rx7club.com/showthread.p...=ecu+grounding
Hope this helps,
Matt
Old Dec 7, 2003 | 06:05 PM
jorx7's Avatar
thanks for the help
Professorpeanutrx7
Aug 15, 2015 01:38 PM
ncds_fc
Aug 15, 2015 10:06 AM
befarrer
Aug 14, 2015 04:18 PM
