grounding
Old Oct 7, 2001 | 04:36 AM
HuggyBear's Avatar
grounding
with putting extra grounds under the hood, i read last night that it should be 4 - 8 gauge wire. is this correct? thats some big *** wire.....
Old Oct 7, 2001 | 01:30 PM
Flobb's Avatar
Rattle can retard
From what I've read it's a minimum of 10-12. I would just stick with 8 though. I think that is the most common size used.
Old Oct 7, 2001 | 08:47 PM
Icemark's Avatar
With up to a 100amp alt, you can use 8 gauge wire up to 36 inches.
All that said I have additional 8 awg wire between the motor and firewall, the ECU and firewall, and 4 awg battery ground (plus the stock wires).
ls1swap
Jun 3, 2024 03:25 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
