Sponsored by: CARiD
Oil Dipstick Pushed out
Old Nov 23, 2003 | 11:05 AM
Jodeny's Avatar
Indifferent
Does anyone know what would cause the oil dipstick to be pushed out of the tube almost all the way. My engine actually squirted oil all over under the hood out of tha dipstick tube....any advice anyone??
John
Old Nov 23, 2003 | 04:05 PM
rxseven's Avatar
Special Dark
Is your oil filler neck vent blocked?
Old Nov 23, 2003 | 05:45 PM
Jodeny's Avatar
Indifferent
yes, its the stock 94 vent though....
John
Old Nov 23, 2003 | 06:23 PM
SNracing's Avatar
aka KingDrunk
did you have the dipstick pushed all the way in? if not, it could of poped off. also is the ring at the top of the dip stick worn or corroded? (sp) if the seal at the top is not tight, it could pop off.
Old Nov 24, 2003 | 09:32 AM
Jodeny's Avatar
Indifferent
No, all of that is fine...
John
Old Dec 2, 2003 | 11:55 PM
SNracing's Avatar
aka KingDrunk
just an idea, but if you had too much oil in there, the pressure may of caused it to pop off, or just having to much oil may of caused it to pop out? when did it happen, while driving or just sitting?
Old Dec 3, 2003 | 03:16 AM
black_sunshine's Avatar
It is also usually a sign of a bad side seal.
Old Dec 3, 2003 | 08:24 AM
Jodeny's Avatar
Indifferent
I will update tonight. I need to take a closer look at some things.
Thanks
John
Old Dec 5, 2003 | 08:19 AM
wickedrx2's Avatar
yes is probably broken side seal, if this only happens when u hit boost and u r having oil being squirt up all the way to the hood it means u have abroken side seal and the boost is leaking right thru it , this happened to me before and out of bad experience i can tell u this
Old Dec 5, 2003 | 09:21 AM
Jodeny's Avatar
Indifferent
Thanks for the info. I actually confirmed it last night- a side seal is broken. What would cause this to happen?
John
Old Jan 11, 2004 | 08:48 PM
Jodeny's Avatar
Indifferent
Update,
it was the black outer oil control ring seal. It got progressively worse from 0 miles to 900.
John
13
Jan 9, 2018 11:19 AM
rotor_veux
Sep 3, 2015 07:10 PM
