Power FC How to change boost setting? Sorry novice question.
Old Oct 5, 2001 | 08:43 PM
SpeedracerRX7's Avatar
I know this is a novice question but I think that I have mine set on the second one but I am only recieveing about .80 on the boost monitor screen. I am wondering if I have that bad of a boost leak or vaccum problem or if I haven't changed it from one to the other. I have setting 2 highlighted in the Settings menu. Is this all there is to it? Thanks for your patience and wizdom.
Old Oct 6, 2001 | 06:54 PM
hercdriver's Avatar
I definately do not claim to be an expert at the PFC but I called my tuner yesterday with a similar question and he told me that whatever setting you have highlighted (eg 80) is the one you are using.
Old Oct 7, 2001 | 12:58 PM
RICKRX7's Avatar
The stock secondary boost setting on the #2 setting is .80. Be careful when changing the boost. I changed mine to .90 and 76% base duty and hit 1.1 Thank god I did not blow the engine. I then changed back to the stock setting.
If anybody knows what I did wrong, please tell me.
Rick
Old Oct 7, 2001 | 02:10 PM
spyfish007's Avatar
Yellow Dragon is no more
do you have the tock pills or do you have the bleed valves installed?
Old Oct 8, 2001 | 08:19 PM
annarborman76's Avatar
My PFC came with the following two settings:
1. Pr 0.80 kg/cm^2 56%
Sc 0.70 kg/cm^2 64%
2. Pr 0.90 kg/cm^2 62%
Sc 0.80 kg/cm^2 70%
Currently I have it on setting 1 and the primary peaks at almost exactly 0.80 kg/cm^2. I think I would like both the primary and secondary turbo to be set at 0.80 kg/cm^2. Will the following setting be the way to do that?
Pr 0.80 kg/cm^2 56%
Sc 0.80 kg/cm^2 70%
Also, how well does the PFC account for the extra boost when regulating the fuel?
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
