Vac questions: When does the VDI solenoid allow aire to flow?
Old Nov 14, 2003 | 07:23 AM
Kenteth's Avatar
Like Ghandi with a gun
So I removed the Vac Rac, but was curious when the original VDI would have had pressure. (when would the solenoid open). If I put a pressure to the solenoid, can I hookup the solenoid and hace the cpu drive the VDI?
Otherwise all emmisions is gone. using an eletric air pump to supply pressure to the 6ports and VDI.
Old Nov 14, 2003 | 07:40 AM
SureShot's Avatar
Seduced by the DARK SIDE
On my 91NA I picked up the ground signal from the Aux port solenoid connector to close a relay & turn on the air pump. The pneumatic rack tee's to both the 6PI & VDI so when the VDI solenoid opens ~5800 the pressure is already there. I bleed off the excess pressure with a spring & ball check made from generic brass fittings.
By the way the ECU will not open either solenoid if the boost sensor sees high vac, or the tranny is in neutral.
Old Nov 14, 2003 | 08:21 AM
Kenteth's Avatar
ahh so, you don't have aux's open at ~3800 But rather open both auxs, and VDI at 5800?
This is what i was looking to do. I just wanted to make it with 1 rpm switch instead of two...
http://webpages.sdsmt.edu/~4392494/a...iondiagram.htm
Old Nov 14, 2003 | 09:19 AM
SureShot's Avatar
Here is the diagragm of my S5 NA e-pump setup.
Old Nov 14, 2003 | 10:12 AM
Kenteth's Avatar
So you're using both solenoid leads from the ECU? It makes sense and looks pretty good, but are the systems only activated underload?
Whats the determination to when the ECU decides weather or not to ground at 3.8 and 5.8?
Old Nov 14, 2003 | 10:21 AM
SureShot's Avatar
I looked them up in the FSM.
Page 76 - fuel & emissions section. The O's indicate a relation.
Air flow meter
Crank angle sensor
transmission neutral switch
clutch switch
Old Nov 14, 2003 | 10:30 AM
Kenteth's Avatar
awesome, that helps alot. Thanks
Old Nov 14, 2003 | 10:59 AM
Icemark's Avatar
Hmmm,
VDI opens at 5200 RPM according to page F1-80 of the S5 FSM, not 5800 (wire 2M).
Old Nov 14, 2003 | 11:24 AM
SureShot's Avatar
Either mine came in late, or my tach was off.
Two years ago, when testing the VDI, it would open at half throttle ~5500.
Last year it tripped at ~5800, and only at nearly WOT?
Anyway - I sold the NA when I got the turbo. (A whole new set of challanges)
Old Nov 14, 2003 | 12:17 PM
Icemark's Avatar
I am actually opening mine at 46-4800 on mine, which I think is a touch low (there really is not much of a noticeable kick in, unlike what others with the S5 conversion report).
Your air pump may have been getting old, or the solenoid valve was clogged (common if a decent air filter was not used for the air pump when a cone filter conversion was done).
Old Nov 14, 2003 | 05:40 PM
NZConvertible's Avatar
I'm a boost creep...
You should use the ECU to operate both the stock 6PI and VDI solenoids, and trigger the compressor relay from the 6PI signal (since it operates first).
As I've said before, leaving the whole thing stock would've been a helluva lot easier, and would work better than anything to put together yourself. All this effort just to remove the air pump and solenoid rack, only to require another air pump and the same solenoids. Where are the gains from doing this?
Old Nov 14, 2003 | 05:42 PM
Kenteth's Avatar
I dunno, I feel like i did something, gain some experience I guess. Like the person that makes a telephone out of a coffeepot. Sure, it was a perfectly good phone before... but now its a phone that looks like a coffeepot. And who can say that have one of those?
24seven_dada
20
Nov 10, 2018 12:03 PM
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
