My DLIDFIS
Old Nov 6, 2003 | 06:36 PM
jsinrx7's Avatar
My DLIDFIS
Ahh! I can finally upload pics to my computer again! Anyway thought you guys might like to see my bad-*** DLIDFIS setup, the pic isnt the greatest, but you get the point and yes that is a HEI module modified to be used as the trailing ignitor, works great and they cost about 1/10 as much as a mazda ign.!!
-Jsin
Old Nov 6, 2003 | 10:44 PM
REVHED's Avatar
Hunting Skylines
Nice. All you need to do now is change the T and L on the coils to 1 and 2.
Old Nov 6, 2003 | 11:23 PM
Hans's Avatar
Re: My DLIDFIS
-Jsin
I was told all I would have to do is just swap (+) (-) around on the input going to the ignitor to make the HEI module work? is this correct?, i got to go pick some up, but want to make sure thats all you have to do first.
Old Nov 7, 2003 | 03:15 AM
Jeff20B's Avatar
Lapping = Fapping
jsinrx7, good job!
I spent some time tonight hooking up one of my cars. J-109 all around. I set it up and tested it a year ago, but took the engine back out. It's back in now and I'm going to fire it up tomorrow.
The HEI ignitors have a W and some other letter on the pickup signal side. I can't remember which wire it goes to on the Mazda dizzy though. Anyway, you have the right idea.
Old Nov 7, 2003 | 12:52 PM
The W connects to the positive lead at the distributor and the G connects to the negative.
I am in the process of doing the DLIDFS mod and I was wondering what guage of wire should I use?
Old Nov 7, 2003 | 01:35 PM
jsinrx7's Avatar
I use 14 gauge for everything except for the power wires, I use 12 for those.
Old Nov 7, 2003 | 07:32 PM
Makenzie71's Avatar
...94% correct.
Looks bad ***!
okay, half the setups I'm seeing are using the stock coils and half are using FC coils. What's the difference?
Old Nov 8, 2003 | 08:44 PM
jsinrx7's Avatar
IMO individual aftermarket coils are better because:
a) they are "hotter"
b) they can be replaced individually
c) MUCH easier to find than 2nd gen coils.
d) and finally, you can say "Who cares about V-TEC, I have three Coils bitch!!"
Old Nov 8, 2003 | 08:55 PM
Rx7carl's Avatar
Airflow is my life
Nice job.
Old Nov 8, 2003 | 10:45 PM
Jeff20B's Avatar
Lapping = Fapping
That would be cool on a licence plate frame.
Old Nov 24, 2003 | 12:42 PM
jsinrx7
I was looking at the wiring picture for DLIDFIS and I was wondering what did you do to connect the positive side of the coils to the ignition switch?
The diagram shows all three positive posts hooked together and then connected to the ignition switch. Is it ok if I just connect the positive posts of the new leading coils together and use the wire that originally ran from the stock leading coil to the ignition switch. I am leaving the trailing coil in the stock location and I am trying to figure out how to get the two leading coils connected to the ignition switch.
Old Nov 24, 2003 | 01:27 PM
REVHED's Avatar
Hunting Skylines
Yep, that'll work fine.
jutny
Aug 14, 2008 06:50 PM
bkm_rx7
Jun 11, 2005 02:28 PM
vipernicus42
Mar 3, 2004 11:26 PM
jutny
55
Feb 13, 2003 12:33 AM
FD Racer
Dec 3, 2002 11:25 PM
