I need help, i'm confused
Old Nov 6, 2003 | 10:43 AM
j-spec_wannabe's Avatar
Rotary []D[][\/][]D
Unhappy I need help, i'm confused
Hey guys i finally got my 1980 rx running good but i just want to know if my car will be alright. I just want to know if i should hook anything back up or if it will be ok. Lets see, i took off my air pump and tapped my actuator inlet and outlet shut, and i took off the rats nest and tore a bunch of stuff off of the carberator. I just want to know what i should look out for or what i should do because my car from 3rd,4th, then into 5th hesitates at 4,000 rpms, i thought it was the fuel pump but i replaced it and its still doing it, and now she puffs a little blue smoke hear and there but not all the time, what do you guys think i really love this car and i need it, i just need help i am new at first gens.
Old Nov 6, 2003 | 11:11 AM
Metallic_rock's Avatar
Ride 'n Style
hmm... my bet- clogged thermal reactor. (assuming you have stock exhaust for an 80)
Fuel filter, maybe?
tune up? - plugs, wires, etc.
Old Nov 6, 2003 | 11:18 AM
Rotary []D[][\/][]D
Yeah it does have the stock thermal reactor, it does have a tune up as well, and a new fuel filter, its alright for it not to have the air pump right? Should i try taking the tape off of the actuator tube inlet and outlet. Also if the thermal reactor is pluged up is there any easy ways to un-plug it?
Old Nov 6, 2003 | 11:54 AM
Rotary []D[][\/][]D
I just got done un-tapping the inlet for the actuator and it runs a little better, noticably, anyway after i shut the car off taking it for a little spin, i noticed about 3 sec afterward a poof noise occured so i do think that thermal reactor is plugged up, so does anyone have any helpful hints on how to unplug it or is just shot.
Old Nov 6, 2003 | 12:27 PM
mwatson184's Avatar
holley guy
buy an rb header. Get one used, they are cheap and they last forever. I was told not to remove the emmissions before getting rid of the TR also, i'll try to find my post about that mess.
-Marques
Old Nov 6, 2003 | 04:07 PM
Rotary []D[][\/][]D
thanks
Old Nov 6, 2003 | 05:21 PM
Rotary []D[][\/][]D
how sure are you guys on this being a faulty TR
Old Nov 7, 2003 | 10:33 AM
Rotary []D[][\/][]D
Could a plugged TR also cause it to puff blue smoke, it only puffs blue smoke when the car is warmed up, then when its warmed up it puffs blue smoke when i let off the gas to shift
Old Nov 8, 2003 | 09:14 AM
Rotary []D[][\/][]D
Old Nov 10, 2003 | 10:08 AM
Rotary []D[][\/][]D
If my TR is plugged would exhaust still come out of it, where should i check to see where its plugged at
Captain Hook
13
Oct 4, 2015 06:35 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
c0rpse
16
Sep 25, 2015 11:33 AM
doritoloco
Sep 5, 2015 12:41 PM
