Is there any chance to read ecu codes without ECL?
Old 11-05-03, 10:08 AM
CapitanCombo's Avatar
Maybe you don't know but european FD DON'T have Engine Check Light, but in it's place a stupid rear fog light lamp
Is there any other way to read engine codes excluding the original Mazda code reader?
CapitanCombo is offline
Old 11-05-03, 05:26 PM
djantlive's Avatar
do you have the diagnostic port in the engine bay? i don't see how you can read the code if there is no CEL flashing to let you count out the code.
djantlive is offline
Old 11-05-03, 05:49 PM
rpm_pwr's Avatar
No problem. The US version was the only version to get the CEL.
Open the diagnostics port in the engine bay. Connect TEN and GND with a link. If you have a fast voltage meter, you can read the voltage on the CEL pin on the diags connector.
Alternatively, just buy an LED and a 680 Ohm resistor and solder them together. Put one end in the CEL pin socket, and the other in +BAT. Like so:
CEL <----- 680R------|< (LED) ------ +BAT
Shoot me a PM if you don't understand this. I have my FD at work today, and can duck out and check the pin names for you.
-pete
rpm_pwr is offline
The following users liked this post:
pietrino (02-07-22)
Old 11-06-03, 03:10 AM
Pete i understand and i do have a diagnostic port in the engine bay
if you can post here a pic indicating the pins to use it would be usefull for all of us european owners
BTW i don't know if we have a CEL pin in the socket.
thanx a lot!
Old 11-06-03, 08:26 PM
rpm_pwr's Avatar
Matteo,
Lift the lid on the diagnostics connector. On the inside of the lid you will see a diagram of the PINS each with a name. Mazda have done a better job than I ever could
-pete
rpm_pwr is offline
Old 11-07-03, 01:55 AM
Yes I know
but i wanted to see if it is differente than mine/ours
i don't have a pin named CEL
just checked
Old 11-07-03, 09:07 AM
jwhite94RX7's Avatar
What rpm_pwr referred to as "CEL" is actually "MEN".
jwhite94RX7 is offline
Old 11-08-03, 12:28 PM
Is it the second from the top left?
see pic
Old 11-08-03, 07:25 PM
djantlive's Avatar
I dont' understand, even if you short the GND and TEN and read with a LED, how does this tell you what code it is? Does the LED flash at you?
Old 11-09-03, 09:05 PM
rpm_pwr's Avatar
aaah ok I will have to check on my car and get back to you. I think it is MEN. Whichever it is, you'll see it changing state with TEN and GND linked.
djantlive -> The LED will then flash out the codes the same way as the US version does.
-pete
rpm_pwr is offline
Old 11-09-03, 09:28 PM
djantlive's Avatar
Interesting, thanks for the explaination.
Old 11-10-03, 02:44 AM
Great I'll try ASAP!
Old 11-10-03, 08:52 AM
I tried the resistor/LED connection between the B+ and MEN terminals with the TEN terminal grounded on an AMERICAN RX-7 (mine). The LED did not flash while the check engine light was flashing. It did come on when I activated any of the E/L circuits were activated, so I think the LED was connected properly.
Perhaps the MEN terminal doesn't flash error codes in AMERICAN RX-7s ? (since we already have a check engine light) [and, yes, I did have an error code stored at the time]
Old 11-10-03, 05:15 PM
rpm_pwr's Avatar
Apologies for all the back and forth here
I repeated this yesterday. The correct pin is FEN (top left). Note that LEDs are diodes so they only flow current in one direction. So if it doesnt come on at all, you've probably got the resistor-led link in around the wrong way.
Mine just flashed out all the usual missing emissions gears codes.
-pete
rpm_pwr is offline
Old 11-10-03, 05:19 PM
rpm_pwr's Avatar
MEN,TEN,FEN you can see why everyone is confused Also, F/P is an open connector for the fuel pump. In diags mode (TEN->GND) you can run the pump to test the FPR and FPD. Also looks like you know what you're doing if there's people watching you work
-pete
rpm_pwr is offline
Old 11-12-03, 08:39 AM
Open the diagnostics port in the engine bay. Connect TEN and GND with a link. If you have a fast voltage meter, you can read the voltage on the FEN pin on the diags connector.
Alternatively, just buy an LED and a 680 Ohm resistor and solder them together. Put one end in the FEN pin socket, and the other in +BAT. Like so:
FEN <----- 680R------|< (LED) ------ +BAT
[snip]
-pete
I confirmed this (as edited) today. With the TEN terminal grounded, the LED attached to the FEN terminal displays the ECU error codes just like the check engine light.
Old 11-12-03, 04:26 PM
rpm_pwr's Avatar
hehe - you thought I was making the whole thing up for a while didnt you?
Also works on the JC Cosmo (both 13b and 20b versions). They dont have a CE light either. Beats me what the codes mean though
-pete
rpm_pwr is offline
Old 11-12-03, 05:25 PM
It wasn't sceptical, but I do prefer certainty.
If I had passed the information to someone else without confirming it, I would have said something like "I haven't tried this, but I've been told ...". Now I can say with certainty "You can connect an LED and ..."
Thanks for the info.
Old 09-04-06, 05:31 PM
Recovering Miataholic
wstrohm's Avatar
MEN = Monitor Enable
TEN = Test Enable
FEN = Flash Enable
wstrohm is offline
Old 09-05-06, 08:57 AM
Rotary Monkey
DS2000's Avatar
Hi guys,
Being in the UK it seems anything is a PITA to get hold of, would one of you be good enough to have a look here (http://rswww.com) and get me the part numbers for the 680R and LED? Simply typing 680R comes back with about 1000x different results.
I'm ok at following circuit diagrams etc but when it comes to choosing the bits I'm clueless.
Thanks
DS2000 is offline
Old 09-05-06, 10:18 AM
tiger18's Avatar
i used a test meter (the one with the swinging needle, not a digital one ) this works fine
tiger18 is offline
Skeese
65
03-28-17 03:30 PM
rocker1337
16
09-06-15 11:28 PM
befarrer
Microtech
08-22-15 05:52 PM
Quick Reply: Is there any chance to read ecu codes without ECL?
