and the question of the day is..
Old Nov 4, 2003 | 07:45 PM
riffraff's Avatar
smog nazi destroyer
well i put some new spark plugs in this morning and got the beast running to find that i cannot get the motor to rev above 3k rpm.. i have narrowed the problem down to either spark or fuel (how do you like them deductive reasoning skills).
and to the question ... on a carbed bridgeport 13b (i am considering my motor a bp for this question) what would be a good fuel pump to use? would the standard holley/carter flow enough volume, or is something else more appropriate?
Old Nov 5, 2003 | 10:42 AM
813KR$'s Avatar
TEAM MAZDA
Sounds good to me, depends on the carb you plan on using. I think the most psi you would need is 6psi for the Holley's. Unless you went to FI which obviously needs a High psi pump. I see you have a Weber I dont think the Webers have as high of psi needs as the Holley's, I think their are more like 4psi, but not possitive. If you cant figure out the Weber psi, I have a RB catalog that has it in there, I will check it out for you. Just let me know and I will look.
Do you think the prob you are having is the fuel pump?
vipernicus42
Mar 7, 2016 04:57 AM
alphawolff
Nov 17, 2015 05:57 PM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
