84 13b rebuild need help on mods
Old Oct 30, 2003 | 05:51 PM
fstfrbrd's Avatar
Angry 84 13b rebuild need help on mods
I just started to take the 13b out of my 84 gslse. ineed to know what i can do to it while i am rebuilding it. i want to get as much hp as i can from motor only. no turbo what can i do
Old Oct 30, 2003 | 05:54 PM
Makenzie71's Avatar
...94% correct.
street port it while the engine's apart. That's about as good as it gets when t comes to internals.
You could also get yourself an S5 flywheel and rotors and e-shaft assembly for that 10,000 rpm stress limit.
Old Oct 30, 2003 | 06:07 PM
Pedestrian X's Avatar
SpAz!
Those components really have a 10K rpm stress limit? I never knew that but I would guess that it does not help that much when the apex seals "limit" beein sumwhere around 8,400?
Old Oct 30, 2003 | 06:11 PM
fstfrbrd's Avatar
who should i get my parts from. rebuild kit ect..
Old Oct 30, 2003 | 06:17 PM
Makenzie71's Avatar
...94% correct.
lol...the S5 rotors and shaft and such can spin damn fast but you're right...the seals and various other things would have to be upgraded to be able to do it reliably...not many people who use those parts intend to spin em that fast...usually they just want the lighter rotors and higher comp.
Old Oct 30, 2003 | 11:55 PM
fstfrbrd's Avatar
people look but dont say a thang
Old Oct 31, 2003 | 12:05 AM
Makenzie71's Avatar
...94% correct.
sorry guy...that's about the jist of internal upgrades...porting...the rest is outside the engine. This isn't a piston engine where you look at machining crank-shafts and forged rods and pistons and stuff...I mean hell you only really got 8 parts IN ALL that you can really modify...
Old Oct 31, 2003 | 12:07 AM
Makenzie71's Avatar
...94% correct.
here ya go...this this just covers porting but it's a cool list.
The mods with your engine pretty much are carburetor, porting, exhaust. Those are the major things.
Old Oct 31, 2003 | 02:36 PM
SpAz!
You can upgrade to 3mm apex seals.
Old Oct 31, 2003 | 02:58 PM
Makenzie71's Avatar
...94% correct.
I thought the 3mm seals were more for forced induction applications...if there are no intentions for turbo charging or supercharging they're kinna overkill...that's just what I had thought...I don't know for certain.
rotor_veux
Sep 3, 2015 07:10 PM
rxmiles
Aug 24, 2015 02:07 PM
sYnth.
Aug 19, 2015 06:27 PM
ncds_fc
Aug 15, 2015 10:06 AM
