buying waste gate, but what size?
Old Oct 21, 2003 | 11:39 AM
jus like it says i need to buy a waste gate but i don't know what size i should be getting this is my set up if it helps. 13b-re, with a 60-1 turbonetics turbo, custom manifold made, 3.5-4" down pipe coned down to 3" all the way back. no cats. i wanna be running maybe i guess 18 psi on the track and 12-15 on the street? is that enough boost to get the most out of that turbo? any help is great thx
Old Oct 21, 2003 | 12:27 PM
BDC's Avatar
BDC
BDC Motorsports
40mm will work fine.
B
Old Oct 21, 2003 | 02:04 PM
thanks alot anyone herd anything bad about tial waste gates? i herd they were very good
Old Oct 21, 2003 | 09:08 PM
boostedrotor's Avatar
BDC is da coolest
Old Oct 21, 2003 | 09:38 PM
eViLRotor's Avatar
Brother of the Rotary
Yep. You can't go wrong with TIAL stuff. I have both the TIAL 46mm WG and the TIAL BOV.
Their gates are very reliable and well machined. Some people have been having slight problems with the BOV's.
Old Oct 21, 2003 | 09:53 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
I use the Tial 40mm without any problems...I also have the tial bov(which I also posted how to setup right in another forum), it needs the light spring to work..max
Old Oct 21, 2003 | 10:28 PM
thx alot guys. i appreciate all the info. well i'm goin with a single 40mm tial den is that a good idea since i will be running higher boost at times? i will be runiing 12 on street and 15-18 on track. single good enough?
Old Oct 21, 2003 | 11:33 PM
Freaky Monkey007's Avatar
I dont mean to sound like an idiot. But since it was brought up what exactly is the difference between a wastegate and a bov?? Im assuming that a wastage is after turbo or on the exhaust side and the bov is on the intake side usually after the intercooler right? Well if this is the case what exactly is a Pop off valve??
Old Oct 22, 2003 | 11:10 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
a pop off vavle is a saftey device used on some stock cars,
it is designed to release at a certain boost level.
so if the car is designed to run a 7psi, the pop off will usually go at 10psi.
it is not controlled by vacuum like a BOV it will just release when a cetain pressure is reached.
Old Oct 22, 2003 | 01:50 PM
Im susprised then that more 7s dont have a pov.. It seems with all of the engines that are blowing b/c of boost spikes this would be the best way to go...
Old Oct 22, 2003 | 08:06 PM
i got the innovative pro-gate, 42mm.....it's pretty sweet..
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
