what turbos should I use?
Old Oct 14, 2003 | 01:50 AM
mr g lord focker's Avatar
I am wanting to run 15 PSI but dont want to do it on stock turbos...what turbos can I use besides stock that will bolt right up that can handle that PSI safely?
Old Oct 23, 2003 | 08:55 PM
PureSephiroth's Avatar
#1 Certified Cone Killer
you could probably upgrade your twins to run 15psi. You could also run a single in your FD and easily run 15psi. Note that you will not be able to do this simply by "bolting up" a turbo. You will need a multitude of other modification to safely run this boost level. Check the single turbo forum. They can help you much more than I can.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
