How to check compression?
Old Sep 27, 2001 | 07:28 PM
fc3s.org's Avatar
OG
Re: How to check compression?
Originally posted by WankelNut
People appear to be saying that one of the surest tests for engine condition is whether it's running at a good compression. Well, on this 86 RX-7 that I'm considering buying for a project car, how and with what do I check the compression and what should the compression be?
Scott Farmer
Rotary Newbie
You should have the car taken to a Mazda Dealer and have it compression checked there. Rotaries have to be comp tested differently than pisston motors, and they use a different comp tester. I personally only trust Mazda for this test.
I think stock is 9.4 : 1 and minimum is 6.0 : 1 with a difference of no more than 1.5 between sides. It's been awhile since I have looked up the N/A info so someone correct me if I'm wrong. Of course Mazda has all of the correct info at the dealer when they do the check. You get a printout with the readings and weather they pass or not.
Old Sep 27, 2001 | 08:37 PM
dre_2ooo's Avatar
86-88 9.4:1
89-91 9.7:1
Old Sep 27, 2001 | 11:58 PM
fc3s.org's Avatar
OG
Originally posted by dre_2ooo
86-88 9.4:1
89-91 9.7:1
Right on! I am not losing my mind completely
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
whinin
Sep 5, 2015 11:52 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
