Idle doesn't stand...!! HELP
Old Oct 1, 2003 | 08:27 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
I swapped my 13B engine in my 83 GS. I am running a dellorto DHLA48. When i started the engine the first time, there was a lot of backfires, and the idle wasn't standing, i had trouble to keep her alive... The brand news 13B header turned red. After starting it a few times and running it at 4-5K rpm, the car was revving much better, and there was no smoke. But i have to hold the gas to keep it alive, if i release it, it dies. Some people told me it could be a vacuum leak in the intake manifold.
I am running a RB complete streetport exhaust, dellorto carb, carter fuel pump, RB upper manifold, GSL-SE lower manifold.
I put new gaskets on the intake, i put sealant to be sure that it wasn't going to leak. I plugged 2 of the 4 OMP tubes on the dellorto like it was on the 12a. The 2 other tubes are connected to the motor, but the hoses are cut ?! ...
another problem i have, my temp sensor and gauge doesn't work.
damn, i hope to find the problem
Max
Old Oct 1, 2003 | 08:54 PM
680RWHP12A's Avatar
run the car and have somebody spray carb cleaner or brake clean will work too. if the idle raises then you have a intake leak
the temp sensor is on the back of the block by the oil sending unit . the wire color is yellow , is it connected?
Old Oct 1, 2003 | 09:00 PM
i'll check by this weekend, my car is at a garage where i work on it.
the problem is that i have NO idle lol... so, i try to handle it maybe to 3000rpm then put carb cleaner.
Max
Old Oct 1, 2003 | 09:04 PM
680RWHP12A's Avatar
that will work, as long as you hold it steady whils somebody sprays the carb cleaner. your symptoms sound like an intake leak
Old Oct 1, 2003 | 09:05 PM
yeah I hope, i'm just too excited to drive it, the engine runs so well, no smoke... can't wait
Old Oct 1, 2003 | 09:06 PM
Hey, but thank Man for all your help !!!! It's really appreciated
Old Oct 6, 2003 | 04:11 PM
Good news, i found the intake leak !!! The car runs superb now, amazing power !
I was happy to drive it, since i didn't drive her for 2 months, the nice sound of the dellorto !
Monsterbox
Sep 11, 2015 03:29 PM
RotaryBobby
Sep 10, 2015 01:33 PM
rx7shirley
Sep 2, 2015 02:11 PM
