Microtech laptop no conect to ecu
Old Sep 30, 2003 | 11:11 PM
Crusader_9x's Avatar
hey all i got a compaq presario laptop. it doesnt have any serial ports on the back of it so i had to go out and get a usb to serial adapter. when i plug everything in and hit f1 or f2 to conect it will onlky stay connected for about a second before it disconects. now if i use my friends old slow laptop witha serial port built in then it will work fine with the microtech all day long. so anyone here got any clues? mine is a 900 mhz running windows xp home if that helps.
Old Sep 30, 2003 | 11:40 PM
10sec rx7's Avatar
what you will have to do is go into hardware settings and change the adaptor to com 2, they default to com 4 usually, once you have done this press f2 and you should connect with out any problems,
Dale
Old Oct 1, 2003 | 09:13 AM
I had that same problem I used a keyspan USB to serial adapter. it defalted to com 9 I changed it to 2. It still wont connect, people have told me that the transfer speed is set to high, but I cant find where to turn it down at.
Old Oct 1, 2003 | 04:07 PM
well i have tried seting it to com 2 and even to com 1 but both wont conect. i will try to turb the sped down and see if that works.
Old Oct 1, 2003 | 04:22 PM
DoingAnything's Avatar
Where did i park my car?
com2 seems to be an issue,
Have you tried com4? that seems to solve the connection issue.
Old Oct 1, 2003 | 04:30 PM
Global Concepts's Avatar
Re: laptop no conect to ecu
We had the very same exact problem! what we did to solve the problem is, We went to the computer store and bought a diffrent serial to usb adapter and that solved it. We finally go it to work!
We used two diffrent serial to usb adapters. One was bought on Ebay and the other was a generic from the store. both did not work. The one we got that works is a pda to laptop adapter (serial to USB). make sure the adapter has XP drivers also.
Good Luck!
Old Oct 1, 2003 | 07:54 PM
well on the microtech only com 1 and 2 are options so i really dont see if setting it to com 4 is gonna do anything. can u elabortate more on which one worked for u? is it the same thing just a different brand? or are u tlaking about to different things? cuz what i got right now is a usb to serial adapter
Old Oct 1, 2003 | 11:22 PM
10sec rx7's Avatar
the one i tryed is a Belkin one, and it worked,
Dale
Old Oct 2, 2003 | 01:05 AM
luiml73's Avatar
Rotary Powered Boobies
I had to buy a USB adaptor and it came with software(Floppy).....Did yours?...
Mine was doing the same thing (connect for two seconds then disconnect). So i switched the cable to the lower USB and WALA!!!! it worked. My Laptop has 2 USB ports.
Try restarting the coputer with the USB cable connected and maybe it will read it.
Or try Add new hardware in the control pannel.
Mine is also a Compaq presario
Old Oct 2, 2003 | 07:49 PM
well windows installed it as soon as i pluged it in so thats not the problem, at least i dont think anyway.
Old Oct 3, 2003 | 05:45 PM
We used Com 1, did not change any settings, The adapter is the same thing and it is a diffrent brand.
iConcepts PDA Serial to USB Adapter
Manufacturer: Sakar International
Mfg Part #: 60446
Product Number: 284605
Compusa Sells It, http://www.compusa.com/products/prod...605&pfp=BROWSE
All I can say is after switching to this adapter everthing worked fine!
It works with Windows XP, That is what we are using.
even tho Windows installs the driver by itself we still installed it from the disk.
befarrer
15
May 19, 2022 10:44 PM
