Stereo Installation : How does one hook up the antenna?
Old Sep 28, 2003 | 01:34 PM
RxRot's Avatar
Hello all,
I'm just curious if anyone knows how to hook up the antenna to an aftermarket headunit? I see the two female plugs...do I need a male/male cable or is there another way? Help would be appreciated.
Regards,
Gavin
Old Sep 28, 2003 | 02:01 PM
rjuge's Avatar
this week i'm driving...
just use the big one only (the smaller one is the diversity if i remember correctly..been awhile)
reception should be fine without it.
Old Sep 28, 2003 | 03:20 PM
RxRot's Avatar
Thanks for the input but how do you connect the two cables? Both the deck and the car have a female connector.
Thanks,
Gavin
Old Sep 28, 2003 | 04:34 PM
Zoomspeed's Avatar
goto an audioshop, radio shack, or autoparts store and get the a male-male antenna cable. plug it up. The smaller one thats for the diversity antenna is not used.
Old Sep 28, 2003 | 09:03 PM
NorthwindHost's Avatar
Mine tip was cut.
Do you know where I can get a another plug for it?
Also, My antenna is broken. All it does is just grind so I just unpluged the switch for it.
Anyone know where I can get a cheaper mast for it as the dealerships are crazy as far as pricing goes.
Old Sep 29, 2003 | 06:52 PM
i have a 34$ 16" mast hid inside my hatch on my fc i got it from best buy in fla
Old Sep 29, 2003 | 09:03 PM
Zoomspeed's Avatar
I had my antenna shaved off, and now I'm using an amplified internal antenna. It cost me about $30 from autozone and measures about 3"x1"x1" from eye balling it. Either way its pretty small, gets good reception, and will fit about any where you want to mount it.
Old Jun 21, 2004 | 11:16 PM
Healeyguy's Avatar
Has anyone setup a Fuba Betaflex D amplified antenna on their car and how's it working out for you? How well did it fit up? Any issues? How is reception of both AM and FM?
Snook
14
Oct 1, 2015 10:56 AM
apooch
Sep 4, 2015 10:27 AM
tiger18
Sep 3, 2015 08:27 PM
