Am I missing a vacuum hose?
Old Sep 25, 2001 | 09:26 PM
whitet777's Avatar
I was just checking the charge relief valve hose today and noticed I am possibly missing a small vacuum hose. At the base where the charge relief valve hose connects to the secondary turbo output tube, there is a small brass nipple that has no hose on it. I see like 2 other hoses that are properly attached. I can't find a hose just hanging around either. Is this common? Would a picture help to explain?
Old Sep 25, 2001 | 10:04 PM
spooledUP7's Avatar
There and back again
If you have a manual transmission then you should have one tube without any vacuum hoses on it. It is for autos and it connects to a vacuum chamber.
Old Sep 25, 2001 | 10:37 PM
whitet777's Avatar
Thank you for the help. I do have a manual trans.
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
