start car in 1st, wait for rpm to drop, put in neutral, car dies
Old Sep 22, 2003 | 06:16 PM
LAracer's Avatar
As the title says, my usual routine is to start the car in 1st to avoid the high-rpm warm up. Then when the rpms drop below 1000 I put it in neutral and let it sit until its warmed up. The last two times I've done this, the engine has quit when I put it in neutral. (I should probably note that I don't drive the car very often. Most recently it went 3 weeks without being driven )
I admit I haven't searched much for an answer, but I've been reading this forum for a while now and have never come across this problem.
Is this something that has been discussed before? Is there an easy solution (yeah, right!)?
Old Sep 22, 2003 | 06:27 PM
DaedelGT's Avatar
Uber Newb.
If you leave it in first gear does it idle fine? What about if you start the car in neutral and just blip the throttle to stop the AWS?
Old Sep 22, 2003 | 06:29 PM
93FD3S's Avatar
Big Snail
Check your clutch switch. Located above the clutch pedal. Its a small electrical switch that that lets the ecu know when and when the clutch is engaged.
Old Sep 23, 2003 | 07:53 AM
LAracer's Avatar
Thanks for the replies
Yeah, in first it idles fine. I didn't know that blipping the throttle would stop the AWS. I'd still like to know why it dies when I put it in neutral though. Might be a symptom of some other problem.
Originally posted by 93FD3S
Check your clutch switch...
The clutch pedal is depressed throughout the entire sequence, so I'm not sure that's the problem. I will check it though, thanks.
Any other thoughts?
Old Sep 23, 2003 | 08:10 AM
93FD3S's Avatar
Big Snail
Whats your vacuum reading. It could be a vacuum leak.
Old Sep 23, 2003 | 10:04 AM
jr's Avatar
jr
There's also a neutral and 1-2 gear switch in the tranny that work in conjunction with the clutch switch to alter idle. Check all of them. Other than that check for vacuum leaks and maybe even TPS adjustment.
Old Oct 1, 2003 | 04:51 PM
HeatTreated's Avatar
Hi Powr FD's
If you check it...
(the 1-2 gear switch is under the car just under the stick shift, on the tranny)
Old Oct 2, 2003 | 09:49 AM
Runnin Away's Avatar
Da RX7 iz my Mistress
check your map sensor hose
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
smikels
Aug 18, 2015 01:26 PM
cam_7779
Aug 18, 2015 07:48 AM
bb6guy
Aug 12, 2015 03:29 PM
