Dual 2.5" on NA?
Old Sep 22, 2003 | 05:54 PM
DEZERTE's Avatar
777** The Anti-rice
Dual 2.5" on NA?
I have full 2.5" exhaust aside the Y-pipe, if i get a 2.5" Y-pipe will it reduce torq for being "too-open" like i read if the exhaust is too open, it will actually reduce torq, or hp.
Old Sep 22, 2003 | 05:55 PM
DEZERTE's Avatar
777** The Anti-rice
I have a streetport also. just thought i'd add
Old Sep 22, 2003 | 06:15 PM
Makenzie71's Avatar
...94% correct.
2.5 is quite large for the engine...even with a mild streetport...however the only downside you're really going to experence us a loss of low-end drivabillity. After you have a completely free-ed up exhaust the only thing the size of the tubing does is move the powerband around...smaller=low end power larger=equals a higher top end. The "Y" and the tubing after will greatly reduce your rate of flow at low rpms and cause a lot of turbulance being 2.5" but after about 5K it'll even out...except for the turbulance caused by the "Y"...
IMHO your best setup would be a 2.5" single...
Old Sep 22, 2003 | 06:24 PM
bottlejockey's Avatar
I have a 2.5in y pipe on my N/A i thought that it helped and did hurt at all.
Old Sep 22, 2003 | 06:28 PM
Makenzie71's Avatar
...94% correct.
but what did you have before?
Old Sep 22, 2003 | 06:54 PM
ajsuper7's Avatar
Nothin But a G Thang
i have 2.5", it's just fine down low and at high rpms(after 6k) it really moves. go with 2.5 it will be just fine
Old Sep 22, 2003 | 08:53 PM
mazdaspeed7's Avatar
mad scientist
2.5" in the y pipe is just fine. 2.5" in the headers is WAY too big. 2.5" in the midpipe is good.
Old Sep 22, 2003 | 09:41 PM
Makenzie71's Avatar
...94% correct.
ummm...he didn't mention anything about the headers...plus most people have to buy headers and no company that I'm aware of fabs headers that big...
Old Sep 23, 2003 | 09:19 AM
rotarygod's Avatar
Rotors still spinning
He knows that. It is just a general statement to cover all the bases in regards to where 2 1/2" pipe is and isn't good.
Old Sep 23, 2003 | 10:39 AM
BlackIceGuitar's Avatar
I always heard that 2.25 to 2.5 was optimal for performance.
Old Sep 23, 2003 | 11:36 AM
DEZERTE's Avatar
777** The Anti-rice
Thanx guys for all the input
Old Sep 23, 2003 | 01:52 PM
mad scientist
Havent noticed you around much... Hows it been going?
Old Sep 23, 2003 | 02:17 PM
Makenzie71's Avatar
...94% correct.
I figured he knew that but I was trying to figure out if he was talking about the "Y" where the header pipes come togethor or the one the divides the exhaust to the mufflers...if you're looking for a real performance gain the 2.5" should be carried pass the split the the mufflers...
Old Sep 23, 2003 | 02:50 PM
mad scientist
Generally, a y pipe is where the one pipe splits into two, while a collector is where 2 pipes merge into one.
Old Sep 23, 2003 | 04:05 PM
rotarygod's Avatar
I've been very busy and stressed with work lately. Need to buy a house in Houston? I've been too tired to get on here and argue lately with all the other pressures.
Old Sep 23, 2003 | 04:53 PM
Makenzie71's Avatar
...94% correct.
hahahaha....didn't even notice that was you...lol...sup?
Old Sep 23, 2003 | 05:10 PM
rotarygod's Avatar
Is the 'other forum' back up?
Old Sep 23, 2003 | 05:20 PM
Makenzie71's Avatar
...94% correct.
which one? PS? Yeah...Blitz got it going again...
James Knox
Oct 22, 2015 05:08 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
