High Rev Alarm
Old Sep 22, 2003 | 01:52 PM
waddlec's Avatar
Newbie
Question High Rev Alarm
I own a 1987 Non-Turbo RX7. Anytime you rev the engine over about 6800rpm an annoying alarm goes off. Does anyone know an easy way to disable it? I owned a 1983 RX7 (bought new) and it never did this.
Old Sep 22, 2003 | 02:22 PM
So close to 12's!!!
why would you want to disable this? its great for racing, you don't have to look at the tach, just shift when the buzzer goes off
Old Sep 22, 2003 | 02:24 PM
twistedriver's Avatar
Finally I have LSD
Where is the alarm connected to?? Mine don't work any more.....
Old Sep 22, 2003 | 02:28 PM
SleeperZzZ's Avatar
its a shift buzzer... or i like to call it the wankel whine
Old Sep 22, 2003 | 02:38 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Dont disable it. It is also the buzzer that goes off when something is wrong with the coolant.
I dont know why anybody would want to disable it. It tells you when to shift when you are racing unless you bring it up to redline every gear then it might get annoying.
Old Sep 22, 2003 | 02:49 PM
1FastT2's Avatar
If you really must know the buzzer is in the instrument cluster and can easily be removed with a soidering iron.
Old Sep 23, 2003 | 12:59 AM
NZConvertible's Avatar
I'm a boost creep...
Re: High Rev Alarm
That's because the redline is 200rpm later! When you here it, shift up. If it's on long enough to annoy you, you need to review your driving style.
Old Sep 23, 2003 | 06:22 AM
genII Drifter's Avatar
If you really want to disable it, you can take off the instrument cluster and poke the speaker out.
Old Sep 23, 2003 | 03:42 PM
Icemark's Avatar
You don't to disable it. It reports over-rev, low coolant, and low oil.
Taking a screw driver to it just makes sure you won't know if an oil line or coolant line breaks until it is way too late.
Old Sep 23, 2003 | 03:45 PM
DaleClark's Avatar
RX-7 Bad Ass
I have seen one or two RX-7's that had bad warning buzzers. Radio Shack has a buzzer that's easy to install in the stock cluster, and sounds JUST like the stock buzzer.
Dale
Old Sep 30, 2003 | 10:34 AM
waddlec's Avatar
Newbie
Thanks for all of the driving advice. I owned an '83 RX7 (bought new) for 14 years. It ran its best when pushed to around 7500-8000 RPMs in 1st thru 3rd gears. The rotary engine was designed for high revs. When I sold it, it still had the original clutch and exhaust system (minus the cat). The only engine work done on it was I rebuilt the Nikki Carb. The ones that included useful info, I appreciate it.
Old Sep 30, 2003 | 10:06 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
well on stock internals and stock everything else power drops off after 6500 so it is pointles to go mmuch past redline.
santiago
13
Jan 9, 2018 11:19 AM
RedBaronII
Sep 20, 2015 11:29 AM
localized
Sep 16, 2015 12:18 AM
ls1swap
15
Sep 8, 2015 05:30 PM
