Backfiring when warming up
Old Sep 21, 2003 | 09:36 PM
Ripzta's Avatar
Heyo,
When I fire up the engine to warm it up for a drive, the exhaust starts to backfire. When the engine is warmed up it stops backfiring. WTF ay!
The backfiring is annoying. I can hear the backfiring more than the engine's idle. A friend of mine says the exhaust could be blocked causing it to backfire but this may not be the case.
Anyone have any ideas why it backfires when warming up?????
Old Sep 21, 2003 | 09:42 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
When was the last time you changed your spark plugs? regularly changing your plugs can eliminate this should fix your problem. Use 9's all the way around.
Old Sep 22, 2003 | 12:47 PM
mor's Avatar
mor
Mine does it too. I have full exhaust though. I also have M2 ECU so probably running a little rich.
Also, in the morning when it's cold you'll run a little rich as well.
I don't think you should worry.
Old Sep 26, 2003 | 01:23 AM
RCastro's Avatar
I have the same problem, I even replaced my exhaust from the manifold back. I know im running rich, although I haven't been able to find out anything i can do about it... My exhaust will *pop* quietly and also gets red hot... I smell gas in my engine bay and even felt around, on the left side of the engine I had a smell of gas on my hands.
Old Sep 26, 2003 | 03:42 AM
Roar 629's Avatar
same here..
it's gettin late..i dun wanna go detail..it happens when startin from cold
Old Sep 26, 2003 | 04:04 PM
Yes it is for sale.
You have got bigger probelms then your exaust, you have a fuel leak. DO NOT DRIVE YOUR CAR AGAIN UNTIL YOU FIX IT. The most comon thing is your FPD. Fix it otherwise your engine WILL catch on fire.
LongDuck
Oct 7, 2015 08:12 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
Rotafuzz
Sep 30, 2015 09:55 AM
dexter snoek
Sep 29, 2015 09:18 AM
