how do i check if my 6 ports are working?
Old Sep 18, 2003 | 03:37 PM
steviep_'s Avatar
Old Sep 18, 2003 | 03:56 PM
Aaron Cake's Avatar
Engine, Not Motor
http://www.aaroncake.net/rx-7/6porttest.htm
Also, at the top right, there is a link called "Search". It is your friend.
Old Sep 18, 2003 | 05:37 PM
SureShot's Avatar
Seduced by the DARK SIDE
I teed in a pressure gage and blew into the tube to check at what pressure they opened.
Then I routed the tube inside with the gage on the end, and did a test drive to see when they opened.
Old Sep 18, 2003 | 11:35 PM
patman's Avatar
Resident Know-it-All
put some grease on the actuator shafts. a finger full ought to do it. start the car. warm it up some. rev to 4k or maybe 4500 rpms. turn off the car and go look. if the grease is pushed to the top of the shafts, they opened.
If they opened and u want to, you can spread the grease back out and go for a short drive. stay at low rpms (under 3500) except once. get in like 3rd gear and accelerate hard to 3900 rpms. (they open at 3800) then pull over and check the grease to see if they opened.
Wasnt that easy?
_Pat
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
Engine stand ready
Aug 14, 2015 10:26 PM
