Haltech What happens to the Oil Metering Pump
Old Sep 17, 2003 | 12:31 AM
MOSTIN's Avatar
what happens to the omp If and when I install a E6K? Can I program the haltech to run the FD omp if I remove the stock computer?
Old Sep 17, 2003 | 03:50 AM
RETed's Avatar
No.
-Ted
Old Sep 17, 2003 | 09:26 AM
TYSON's Avatar
WTF is wrong with it now?
You need the E11 for that. It has a map in it for the OMP, but who knows if it's right, or what you should change it to
Old Sep 20, 2003 | 02:49 PM
suganuma's Avatar
no
i just left mine on there plumbed in, but with no wiring.
Old Sep 21, 2003 | 08:35 AM
rxrotary2_7's Avatar
block it off and start premixing, or adapt an 87 mechanical OMP
Old Sep 21, 2003 | 06:21 PM
MOSTIN's Avatar
If the Turbo II or the engines that uses mechanical OMP maybe I will have my own to trigger at a predetermine RPM by using any of the electrical connections the pump uses that lets oil thru the lines, I know its is proportional to either engine load or rpm, but i will settle for just a constant injection at any rpm above 5000. Either hook up a micro switch on the throttle or use an out put tiggered by an RPM from the E6K
Old Sep 22, 2003 | 07:22 AM
i believe the OMP will work at a 50% duty even with no power. i really think you should search this topic as it has been discussed/tried/failed many times w/ an FD OMP.
Old Oct 3, 2003 | 03:46 AM
20B_FC's Avatar
We have it figured out finally. You'll need the E11's tho.
Check out:
http://www.k2rd.com/haltech/drawings/OMP03.pdf
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 31, 2015 07:49 PM
