What happened to my suspension?
Old Sep 22, 2001 | 05:51 PM
thatoneguy's Avatar
I hit a curb on the front passanger side. When I got the front end aligned, the camber on the wheel was way off. He set it to the furthest negative setting, and the wheels is still off and the car pulls to the right slightly. Could this be a damaged lower control arm? Thanks.
Old Sep 27, 2001 | 07:22 PM
SleepR1's Avatar
Re: What happened to my suspension?
I hope you didn't hit that curb going at 180 mph! That would explain your problem I haven't had a long enough stretch of road to peg speedo. The closest I got was an indicated 170 mph...
The lower control arm is a very strong piece. It's forged steel (I think). In fact the lower control ball joint is what goes bad. It's possible you bent a tie rod. That's where toe is adjusted. The camber differences shouldn't make the car pull to one side. It sounds like a toe in/out difference between left and right wheels.
Old Oct 10, 2001 | 12:16 PM
carcrazy's Avatar
The lower control arm is actually made of aluminum - notice the nice silver cover that does not rust.
take care
Ricky Boyd
1993 RX-7
Old Oct 11, 2001 | 12:09 PM
SleepR1's Avatar
take care
Ricky Boyd
1993 RX-7
Yes you're right. I was thinking of the upright hub carriers. They're forged steel. The paint must be very durable on the hub carriers, because there's no rust on this suspension piece, and my car's 9 years old with 89,000 miles!
Cuzzynz
141
May 28, 2020 09:23 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
localized
Sep 16, 2015 12:18 AM
