20b subframe and bolt-on bumpsteer correction kit
Old Sep 2, 2003 | 11:35 AM
94RHDFD's Avatar
Formally 20b 3rd gen
What's up Guys
I am starting this tread to see what kind of interest I get for a 20b subframe and bumpsteer correction kit for FD's that I will be selling shortly. The price will be $1700 w/ good core and $1900 w/o. The subframe will use FD 13b motor mounts and the bumpsteer kit is a bolt-on. I should have pics by weeks end.
Old Sep 3, 2003 | 06:48 AM
bermuda20b's Avatar
Sounds good.
I am curious though as I use Pettits subframe/spindle assembly and don't have an issue with the bumpsteer...
Old Sep 3, 2003 | 07:52 AM
94RHDFD's Avatar
Originally posted by bermuda20b
Sounds good.
You shouldn't if you have the spindles, without the spindle mod you would have severe bumpsteer
Old Sep 6, 2003 | 08:53 AM
94RHDFD's Avatar
Hey guys, no pics as of yet, ran into alittle problems but already have found a solution, I will post pics as soon as I can.
Old Sep 7, 2003 | 10:24 AM
SomeGuy_sg's Avatar
Mmmm....sounds good to me , 20B . whats the new subframe made of ?
Old Sep 8, 2003 | 02:47 PM
Dragon's Avatar
20B N/A Wide Body FC3S
will you sell just the bump steer kit? Also how far do you drop your rack?
Old Sep 8, 2003 | 08:06 PM
94RHDFD's Avatar
What's up Dragon, I thought you were almost done with your install? The rack was moved forward just enough to just clear the oil pan, and reajust'd the bumpsteer kit to realign the rack. I don't have a problem sellig the kit but I don't know if it will work with your subframe, you are more than welcome to try.
Old Sep 9, 2003 | 06:21 PM
Dragon's Avatar
yep, I'm well on my way to being done, but I haven't played around with the bump steer issue yet. I want' to see how bad it actually is. E-mail me a few pic's of the bump steer stuff and I'll see if that will put things the way I'm setting my car up in check, lol, or make them worse..
Old Oct 1, 2003 | 11:23 AM
YayeR's Avatar
sounds good to me
Old Oct 1, 2003 | 12:27 PM
Dragon's Avatar
K.. the bumpsteer sucks *****.. lol...
Old Oct 1, 2003 | 04:53 PM
YayeR's Avatar
so i guess this modification is inevitable if i'm planning a 20b conversion? what exactly is 'bumpsteer'?
Old Oct 2, 2003 | 12:02 PM
Dragon's Avatar
Hit a bump and your car will steer somplace you don't want it to.. feels squirly.. I adjusted the toe in a little today and she feels much better, but I'd still like to eliminate it completely..
Old Oct 4, 2003 | 10:36 AM
just use spacers between your spindle arms and tie rods.just like lane and brian used on the ls1 conversion.all pettit does is take your old spindles.cut the arms off and reweld longer ones on,and then rapes you on price.as where hinson just used spacers,which eliminates it too,and only cost at the most 20-30 bucks to do it yourself.
or if you move the rack forward just move it 4 3/4 inch forward.as the rack is 2 3/8 behind the spindle and tie rod connection it will now be 2 3/8 in front of it.
Old Oct 8, 2003 | 09:09 PM
rxman720b's Avatar
Also I have found out through experience that you REALLY need linear springs on the front when you move the rack. Just to see I put some new progressive springs on the front and man did it get squirly. No loss of control per say but I did not like the way it felt. With the Pettit subframe and linear springs up front. I have no bumpsteer. Even @ 150 mph!
Old Oct 9, 2003 | 06:43 PM
peejay's Avatar
Old [Sch|F]ool
The only problem with moving it forward is you lose Ackerman. Makes for a more plowy driving experience. (If you've ever driven a Fox-body Mustang you know how it feels to have steering with insufficient Ackerman!) But it's better that than bumpsteer.
Old Oct 9, 2003 | 09:56 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
another pic...
another pic..
Old Oct 9, 2003 | 10:05 PM
Herblenny's Avatar
order of the pics are *** up.. here is another..
Old Oct 9, 2003 | 10:20 PM
94RHDFD's Avatar
Okay guys, these are the pics of the subframe I know they are not in any order but forum has been acting funky tonight and they did not post correctly. Sorry it took so long. Thanx for posting them for me Phil
John
Old Oct 9, 2003 | 10:29 PM
Herblenny's Avatar
Old Oct 9, 2003 | 10:35 PM
Herblenny's Avatar
all three pics.. showing for those don't want to click..
Old Oct 10, 2003 | 10:56 AM
94RHDFD's Avatar
Anyone interest'd in purchasing the kit you can contact me through PM or email me @ rotaryxs@yahoo.com
Old Oct 12, 2003 | 09:47 PM
TitaniumCranium's Avatar
The Overattempter
Do Pettits spindles keep the same steering ratio as factory?
Old Oct 13, 2003 | 05:06 PM
t-von's Avatar
Rotor Head Extreme
What are linear springs?
Old Nov 11, 2003 | 02:32 PM
94RHDFD's Avatar
bump
Old Nov 11, 2003 | 07:36 PM
RotorMotor's Avatar
DRIVE THE ROTARY SPORTS
ok i have a few questions: here is what i have so far just so you know... FD, cosmo front clip. ok some questions.... how is your kit different from pettits? you say it uses 13b mounting points? what do you mean? would i have to change my rear plate on my 20b? basically i want to know the differences between yours and pettits, cause i will buy one of them. thanks heath
