RB 12A Race Rotors
Old Aug 31, 2003 | 01:54 PM
The_7's Avatar
Registered Piston Eater
RB 12A Race Rotors
racing beats race rotors for the 12A are modified 74-75 rotors - are these lighter than the 81-85 12A rotors?
Old Aug 31, 2003 | 02:32 PM
Sk8r_dude's Avatar
Zoom - Zoom...
donno...if i rebuild, i want renisis rotors, no word on if they'll fit yet...
Old Aug 31, 2003 | 02:37 PM
hornbm's Avatar
FD > FB > FC
dont know if theyd be lighter, but the comnpressions would sure be a hell of a lot lower.
Old Sep 1, 2003 | 12:14 AM
The_7's Avatar
really? why? im building an n/a so anyone know where i can get some lightweight, normal comp ratio (or maybe a lil higher), 12A race rotors?
Old Sep 1, 2003 | 11:58 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
The RENESIS is a 13B so I don't think the new rotors will fit a 12a.
Old Sep 1, 2003 | 06:45 PM
REVHED's Avatar
Hunting Skylines
From looking at the RB website it seems like the only thing they do to the rotors is install the circlip. If you're worried about the compression you can have this same process done to any rotor you want as well as lightening and balancing.
But, I'd find out the compression first. I can't seem to find any numbers on the 74-75 rotors but I know that all 76-85 12A's have the same compression.
Old Sep 1, 2003 | 06:57 PM
The_7's Avatar
well stock compression is fine for me because when you raise compression you drop displacement. im really interested in lightening tho, what is actually involved in the rotor lightening process?
Old Sep 1, 2003 | 07:21 PM
REVHED's Avatar
Hunting Skylines
These are some lightened rotors. You can see where the material's been removed.
Old Sep 1, 2003 | 07:32 PM
diabolical1's Avatar
come again?????
the crude explanation is that they basically grind away the sides of the rotor that seal against the intermediate housings. they just leave contours of the original material so that they can support the side, corner and rotor o-ring oil seals.
they do them in pairs and for extra money they can balance your rotating assembly, but you'll have to send the shaft, flywheel and main pulley with the rotors.
EDIT: okay, Revhed provided pictures while i was responding, so there you go ...
Old Sep 1, 2003 | 07:52 PM
The_7's Avatar
how much do stock 81-85 12A rotors weigh?
how much approx. weight can you lose safely before the rotors become to fragile?
diabolical1,
to raise the compression of the engine you can have a smaller indentation in the faces of the rotors. this decreases the volume at BDC and TDC by the same amount, therefore making the compression ratio higher. but since you have a smaller indentation the displacement drops.
Old Sep 2, 2003 | 07:30 AM
Rx7carl's Avatar
Airflow is my life
http://www.mazdatrix.com/faq/rotorwgt.htm
Ahhhh, thats the million dollar question. Anyone who really knows the answer to this will not tell. You dont want lightweight rotors anyway dude, unless you just hit the lottery?
Old Sep 2, 2003 | 09:03 AM
mwatson184's Avatar
holley guy
I disagree with that displacement and compressions statement. There will be an equaly smaller volume at both bdc and tdc when you raise the comp, so when you subtract to get the displacement it will turn out the same as with the lower comp. The volumes will be lower, the disp will be the same.
Old Sep 2, 2003 | 02:40 PM
The_7's Avatar
isnt displacement volume at bdc?
Old Sep 3, 2003 | 01:56 AM
mwatson184's Avatar
holley guy
Nope displacement is simply the difference in volumes.
Think of it in non car terms, what does it mean to displace fluid in a bucket? The bucket has marks to measure volume, and the fluid is at 4 liters. You have an empty 1 liter bottle and stick it inside the fluid, it will raise to the 5 liter mark. 5-4 = 1 liter difference, or 1 liter of displacement.
-Marques
rx7brandon
Aug 16, 2015 10:55 AM
Marty RE
Aug 13, 2015 11:19 AM
