thought id complain...
Old Aug 21, 2003 | 03:17 PM
onepointone's Avatar
i say what i want
i just replaced a rotor on my rex because i had a brake keep locking up. at first it was the driver one, and my dad (being the nice guy he is) decided to take the liberty while i was at work and replace it for me . that worked for a little while, and i realized the other one started doign it, but worse. i took the wheel off, took the caliper off, and put a screwdriver up to it and notice it was warped really bad (the other rotor had a HUGE crack in it). so i decided i would replace it since i had another one laying around. man.. that bolt thats on the bottom of the caliper housing . that thing was such a pain in the *** to get off. i could only get it out to a certain point, then i realized id be able to pull the rotor off, so i did. well, when it came time to put the rotor on, i put it on, then i played with that bolt and it wouldnt come out all the way before of the tie rod bar. i coudlnt get it in any position that would let the caliper housing to go back on. i almost took the whole strut housing off (which is what ill do next time, and suggest anyone else does) but i finally backed off the bolt on the rotor a little bit and it let it back on, but it was still a pain in the *** to get that bolt threaded. moral of the story.. mazda did a shitty job placing that bolt right there.
its on, so im going to go for a test drive.. thought id complain a little
Old Aug 21, 2003 | 05:30 PM
Rx7carl's Avatar
Airflow is my life
Hah, yea that bolt is a biotch. I remove one of the strut bolts and rotate it till I can get it out.
Old Aug 21, 2003 | 09:34 PM
The_7's Avatar
Registered Piston Eater
that bolt indirectly caused a hole in my garage wall
yea thats coolest way, a box end wrench helps alot too
Old Aug 21, 2003 | 09:52 PM
i say what i want
well, it almost "indirectly" caused wrench in the side of my fender. im pretty good about not hitting things like that. last week me and a friend were working on his bmw when he couldnt get a bolt to thread, randomly he takes the ratchet and throws it into his fender .
Old Aug 21, 2003 | 10:02 PM
The_7's Avatar
damn, if im gonna throw something i just launch it into the wall cause that doesnt really matter, i would never hurt my 7
Old Aug 21, 2003 | 10:10 PM
i say what i want
thats what i keep telling myself
renjiv2
57
Jan 25, 2024 03:34 AM
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
