wiring front side marker as "euro turn signal"
Old Aug 15, 2003 | 04:28 PM
jester1341's Avatar
i've looked and havn't seen a write-up on wiring the FS marker as a side turn signal. i did this to my '86 MKiii, not only is it a neat custom thing it's also handy for some of those less observing drivers out there . the procedure is basicly to run a length of wire spliced into the "blinking wire" of the turn signal to the severed end of what used to be the ground wire of the side marker.
since i am not firmiliar with the wiring of FC's can anyone tell me which wire it is that is the "blinking wire" and if it matters which wire i use on the side marker, since it works no matter which way you insert the bulb.
thanks
Old Aug 16, 2003 | 11:01 AM
jester1341's Avatar
bump
can anyone at least tell me which of the three wires on the front marker/turn signal is the one that makes it blink???
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
PhillyFC
Aug 21, 2015 06:36 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
tsmith94FD
Aug 16, 2015 05:41 PM
