Would fuel system cleaner do the same as ATF?
Old Sep 17, 2001 | 09:13 PM
skibum9199's Avatar
college student
Well, i dont think running it has any negative effects... I run it every once in a while in the hope that it does clean up the carbon a bit, but the motor doesnt run as smoothly when its running the cleaner through. I don't think it helps nearly as much as the atf treament does, but it ought to help a little.. my 2 cents,
~Jesse
Old Sep 17, 2001 | 09:42 PM
relvinnian's Avatar
Fuel system cleaner will lower your octane which is not good on a turbo car. Also, it will not work the same as ATF. The whole basis of the ATF treatment is letting it soak your seals for AT LEAST 24 hours, to break the carbon deposits down. Also, that fuel system crap doesn't work very well, even the techron injector cleaner. But, I assume you are referring to like Slick 50 high mileage fuel system treatment... yeah it will not do much.
Old Sep 17, 2001 | 09:47 PM
nitroracer's Avatar
Dub'N
hye i was just thinking of that prolong stuff will that work. or that other stuff
Old Sep 17, 2001 | 09:53 PM
snoopster76's Avatar
Twisted Girl Chaser
will be doing the atf tomorrow
I'll let you guys know how it works after tomorrow.
Old Sep 17, 2001 | 10:02 PM
skibum9199's Avatar
college student
The high mileage stuff that is supposed to re seal, re finish, or whatever the metal parts inside your engine is bad news... The slots that your apex seals move in and out in will become clogged, keeping hte seals from moving, thus losing compression. I would NOT under any circumstance put that stuff in my eninge...
`Jesse
Old Sep 17, 2001 | 10:17 PM
Twisted Girl Chaser
good to know
my friend was thinking of doing this so i'll tell him not too. It makes perfect since. Thanks.
Old Sep 18, 2001 | 01:08 AM
Ryde _Or_Die's Avatar
Re: good to know
Hey snoopster76...did you need to do any other fuel or ECU upgrades with the upgraded fuel pump? I think my fuel pump might be done & I was thinkin of upgradin while I'm at it. How much did it run you? Thanks.
Chris
Old Sep 18, 2001 | 12:05 PM
Kelimutu's Avatar
Injectorcleaner
The only stuff i´d use in a rotary is Redline S1 fuelinjector cleaner, this actually works and does not seem to do any damage, but all the other stuff that claims to clean out valves and psitons i dont touch, since they are designed to go around inside the engine. Not good for e rotary.
///Kelimutu T2-89
Snook
21
Sep 1, 2015 06:32 PM
82streetracer
Aug 23, 2015 09:28 AM
