newbie question - removing alternator pulley
Old Aug 8, 2003 | 07:35 PM
The_7's Avatar
Registered Piston Eater
i need to remove my stock alternator pulley to put on my new dual belt pulley but i cant get the bolt to break loose. i have a very limited selection of tools. i cant think of how to get the pulley to stay put while i loosen the bolt. i know there is most likely a tool for this but i dont have it and can really afford to shell out the money to get one unless i really need it. so can i get it off using regular tools?
Old Aug 8, 2003 | 07:45 PM
tmiked's Avatar
Waiting for the RX-9
Borrow an air or electric impact wrench.
Old Aug 8, 2003 | 07:52 PM
The_7's Avatar
lol, almost everytime i get stuck with my limited tool selection an impact wrench will solve the problem. im sick of this, im going to autozone tommorow and buying one
Old Aug 8, 2003 | 08:17 PM
Rx7carl's Avatar
Airflow is my life
Or try to squeeze the belt tight (the alt is still on right?) to hold the alt still while you bust it off.
Old Aug 8, 2003 | 08:33 PM
The_7's Avatar
no i took it off, i could put it back on and try that but im going to get the impact wrench anyway since its so useful for working on cars.
Old Aug 8, 2003 | 10:54 PM
REVHED's Avatar
Hunting Skylines
I doubt the belt trick would work as that bolt is usually really tight. I was able to remove it by jamming a screwdriver in between the cooling fins. If you're careful you won't break anything.
Old Aug 8, 2003 | 11:27 PM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
Breaker bar...Put a bar under the pulley drive, push down on the end of the par (locking the pulley drive)while someone else breaks the nut free. Works all the time for me on on pulleys and belt drives. I do it every time I have to change implements on old tractors. Hell, you can manage to break it yourself that way if you've got good upper body strength!
Old Aug 9, 2003 | 12:36 AM
rxtasy3's Avatar
U could probably find an auto repair shop that will swap them for ya and charge very little if nothing at all.
Old Aug 9, 2003 | 02:32 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Yeah use a big screwdriver and jam it in the fins and hit the socket wrench with a hammer. It should come loose. I did mine that way and didn't break/bend anything.
Old Aug 9, 2003 | 11:45 AM
The_7's Avatar
i tried to lock it with a screwdriver in the cooling fan but as soon as i starting trying to loosen the nut i saw the fin starting to bend so i stopped right away.
Old Aug 9, 2003 | 11:01 PM
johnrocks's Avatar
Forget AutoZone. Get the Sears brand.
Peace-
Old Aug 10, 2003 | 07:01 PM
dr0x's Avatar
pei > caek
Autozone and the such usually will just buzz the pulley off for you for free. They do for me anyways...
Microtech
30
Apr 23, 2016 06:37 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
The Shaolin
Sep 14, 2015 07:50 PM
highspeedrider
Sep 8, 2015 07:55 PM
