Turbo Hot Side Glowing Red?
Old Aug 1, 2003 | 12:35 PM
darkwaveboi's Avatar
Need donor car in Fairfax
My hot side of the turbo glows a bright red (seeable at night only). I have 130 miles on a fresh rebuild, have straight through exhaust all the way back. Manifold isnt glowing, center section isnt glowing, only hot side. While driving i did not have the under body panel installed and just installed it. No hard driving, no boost, and no RPMs above 4k rpm. This normal?
Car idle completely rock solid at 900rpm. no vac leaks and car just tweaked by Rotary Performance.
Old Aug 1, 2003 | 12:38 PM
J-Rat's Avatar
Alcohol Fueled!
That is kinda odd.... Ive never seen my Turbo glow.
Old Aug 1, 2003 | 12:39 PM
SureShot's Avatar
Seduced by the DARK SIDE
Sweeet - now you know why heat shields are important.
Old Aug 1, 2003 | 12:44 PM
J-Rat's Avatar
Alcohol Fueled!
Why? So you cant see the glowing turbo?
Old Aug 1, 2003 | 12:45 PM
pillage6's Avatar
You may be running lean.
Old Aug 1, 2003 | 01:43 PM
i thought glowing red was running rich from post ignition of gas in the turbo? the DP doesnt glow either. ONLY the iron
Old Aug 1, 2003 | 01:54 PM
SureShot's Avatar
Ever mess with a torch?
Too much gas or not enough O2 & it's colder..
Rich exhaust will heat up a cat, but not a turbo..
Old Aug 1, 2003 | 02:01 PM
2a+RoN's Avatar
I've seen my turbo glowing numerous times after a good hard run.... always thought it was pretty normal.
Old Aug 1, 2003 | 02:08 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
He said he kept the rpms under 4k. Is it still normal? Inquiring minds want to know.
Old Aug 1, 2003 | 02:15 PM
adamlewis's Avatar
Back from teh deadly!
Is it glowing after city driving or highway driving?
If its city driving under 4k, Id be inclinded to say you have a problem. If its highway driving, Id say its normal.
Old Aug 1, 2003 | 02:35 PM
2a+RoN's Avatar
oh wow! I didn't even read that part. Yeah mine only glows after some real hard runs. 4k... I dunno why it would be glowing then. egt is hotter the more lean you are correct?
Old Aug 1, 2003 | 02:56 PM
Aaron Cake's Avatar
Engine, Not Motor
He's running too rich. Fuel is combusting in the turbo instead of the engine.
Old Aug 1, 2003 | 03:00 PM
you have a EGT gauge or a A/F gauge, so u can tell us if you are running lean or rich?
E
Old Aug 1, 2003 | 05:08 PM
nah, i dont even have a water temp gauge, mine stopped working after the reinstall..along w/ my oil press. gauge.
In a week im going to get an aftermarket watertemp, oil temp, and oil pressure gauge.
Im doing 75% city, 25% highway..but yesterday i was doing all city
Old Aug 1, 2003 | 06:21 PM
BlackFC's Avatar
This can also be caused by ignition timing being retarted. This is not an odd cocurance after a hard run, but is not normal after a sunday drive. Check your timing.
Microtech
Aug 23, 2015 11:04 AM
