Now What?
Old Aug 1, 2003 | 09:20 AM
Now What?
Ok so my car would just totally lose power at around 4k right when the secondaries kick in. So i went and got some that were just cleaned and blue printed put those in and it still has no power at 4k on up. What else could it be? I was thinking pissibly the resistor pack but would that just make 2 of them stop working if it went? TIA
Old Aug 1, 2003 | 09:23 AM
Black13B's Avatar
In Full Autist Cosplay
Bad ground to about a million different things causes the hesitation.
You sure your Aux ports are even opening?
Old Aug 1, 2003 | 09:28 AM
it's not the famous hesitation. There's no power from 4k-redline. my ports are wired open so i know it's not that.
Old Aug 1, 2003 | 11:10 AM
J-Rat's Avatar
Alcohol Fueled!
So, describe "no power". Can you reach the redline? Do you have to keep your foot BARELY on the gas to do it?
Old Aug 1, 2003 | 09:13 PM
That's exactly it. So what do i do?
Old Aug 1, 2003 | 10:16 PM
J-Rat's Avatar
Alcohol Fueled!
Figure out why your Secondaries arent coming online.
Check the easy stuff first, connectors, etc...
Old Aug 2, 2003 | 12:50 AM
Ok i'll have to check everything tomarrow, but this might have something to do with it, when i run the sensor check on my safc the first reading is around 4v and it used to be around 2. anyone know why this might be and what would cause this?
Old Aug 2, 2003 | 01:10 AM
rx7raca's Avatar
wHiTe kNiGhT
are u sure u put them in rite? maybe put them in so they dont face the port, i almost did that.
Old Aug 2, 2003 | 01:21 AM
the injectors face straight down and the connector points straight out. how can you put them in wrong?
