Wtf
Old Jul 29, 2003 | 11:19 PM
FB II's Avatar
Wtf
ok, so i got the carb rebuilt, tonight went to start it and it cranked right up. then i shut it off, tried to crank it up again and nothing. i looked at the front bowl and it's completely full. how do you adjust the floats so they come down just a bit? get a new spring? one more thing, would that cause my idle to be all lame? cause now it idles really rough, and there CANT BE A VACCUM LEAK!!! AHHHHHH, i have searched and replaced everything.
Old Jul 29, 2003 | 11:25 PM
wwilliam54's Avatar
it WILL run
mine wont idle beacuase of dead apex seal springs
just a thought
Old Jul 29, 2003 | 11:49 PM
FB II's Avatar
well, every now and then it will hold it's idle. but after i run it down the road and what not, and come to a stop it wants to die. when i shut it off the front bowl is FULL. so it's like a flooding problem maybe. when i first put the carb on there, it actually held a really good idle. slowly today during the time i had it out on the road it got worse and worse. i JUST DONT GET IT! AHHHHH!
Old Jul 29, 2003 | 11:57 PM
wwilliam54's Avatar
it WILL run
is the vent solinoid hooked up
the valve stem seat on the frot bowl may be bad
Old Jul 30, 2003 | 12:31 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Sounds choke related
Old Jul 30, 2003 | 03:18 AM
FB II's Avatar
i am forking lost on this. brand new plugs and it idles very choppy. i'm checking the floats again tomorrow. and the needle seats are new. ?????? ugh. i'm thinking of going back to the 13b n/a swap that i already have almost all pieces for. geez :-/
Old Jul 30, 2003 | 10:36 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Did you replace the needles and seats without resetting the float level?
Old Jul 30, 2003 | 10:50 AM
excitingleopard's Avatar
Prosthetic head.
WTF, OMG, BBQ!!!
Old Jul 30, 2003 | 11:01 AM
Rx7carl's Avatar
Airflow is my life
Yea re-check the float drop and shutoff. Look at the manual for info on it.
Old Jul 30, 2003 | 12:22 PM
Here's a thought...ditch the Nikki.
Old Jul 30, 2003 | 02:41 PM
FB II's Avatar
lol, i am feeling that nate.
Old Jul 30, 2003 | 04:03 PM
Rx7carl's Avatar
Airflow is my life
HEY HEY HEY!!!!!!!!!!!!!!!!!!! Blasphemer!
Old Jul 30, 2003 | 04:13 PM
Makwana's Avatar
Haha
Old Jul 30, 2003 | 04:30 PM
FB II's Avatar
CARL! i set the floats to spec. they were off a bit. i havent put it back on yet, but i was wanting to make sure that it's ok to plug the aab hose. i didnt do it before and i'm thinking it MAY have added to the junk idle sometimes, idunno. let me know please!
Old Jul 30, 2003 | 05:58 PM
Rx7carl's Avatar
Airflow is my life
Yes plug the AAB hose on the manifold end.
Old Jul 30, 2003 | 08:32 PM
FB II's Avatar
OK, i reset everything. it's ALL GOOD. car W O N T S T A R T............. ummmm. the floats are only half way full now, plugs are good. aab is blocked. whyyyyyyyy
Old Jul 30, 2003 | 10:13 PM
Rx7carl's Avatar
Airflow is my life
Halfway in the window is perfect! Will it shoot gas if you pump the gas pedal? She may be flooded now, look into it some more and let us know whats up.
Old Jul 30, 2003 | 11:46 PM
FB II's Avatar
i needed to jump it, the battery died from last nights continuous starting errors and it started raining so i had to prolong till tomorrow morning! i will let you know though. i'm getting real excited, i want this baby to run right!!!!!!!! hahahah, thanks for all the help! until tomorrow fellas,
Old Jul 31, 2003 | 05:24 PM
FB II's Avatar
OK OK OK, well after resetting the floats here is whats going on:
it cranked right up. i let it warm up a minute. turned it off. it cranked right up again! woot. now, when i took it out for a drive, it was very underpowered. the secondaries were kicking in, but it just wasnt the umph that it even had when it was way fuxd up. but it cruised nicely with out any real bucking or anything. so i park it and let it idle. it's idling a little rough, i messed with the mix screw and it changed nothing. i look down the carb and see that the primaries are spritzing the fuel correctly, but the left barrel of the secondaries was also DRIPPING fuel. only the left (from the passenger side). sooo, i think that may be causing my underpower ness too? what could this be from?
Old Jul 31, 2003 | 05:59 PM
Rx7carl's Avatar
Airflow is my life
Re Check the sight glass for that barrel thats dripping.
Are your secondaries mechanical or vacuum?
Look on my cardomain page for a possible fix (down near the bottom of the page (carb return spring)
http://www.cardomain.com/member_page...=266801&page=4
Old Jul 31, 2003 | 06:28 PM
FB II's Avatar
HOLY ***! hahahahhahaahha THANK YOU CARL! i forgot to put that thing back on the spring lock. all the power is back!!! YESSSS! but, i still have a slight rough idle, and it sputters when i drop a gear real fast. i think it's from too much fuel in the secondaries at the burst. it's still dripping in that one barrel. hmmm. i'm about to check the rear float window.
Old Jul 31, 2003 | 06:31 PM
Rx7carl's Avatar
Airflow is my life
Glad to help! Keep up the good work, your getting there!
Old Jul 31, 2003 | 06:44 PM
FB II's Avatar
ok, looked at the rear window, it is around half way, maybe just a tad under. ????? my secondaries keep getting gas in them. man this sux. what could this be?
Old Jul 31, 2003 | 06:45 PM
Wankelguy's Avatar
This is better than a soap opera, I can barely wait for the next episode! "Will FBII get his carb sorted out? Find out in the next episode of 'As the Carb drips"...
Old Jul 31, 2003 | 06:50 PM
FB II's Avatar
HAHAHAHAHHAHAHAHA niiiiiice! i will win the game!
