how long can it last?(compression results)
Old Jul 29, 2003 | 08:15 PM
Ryde _Or_Die's Avatar
Well I don't have the actual numbers, but my mechanic told me my compression results were like 80- 85's all around. How bad is that exactly? Can it last a long time being that low or am I needing a rebuild real soon?
Old Jul 29, 2003 | 08:34 PM
rotary>piston's Avatar
a long time, or a short time. It really depends on the rest of the engine. It may blow tomorrow, or in 10 years. A compression check is a pretty crude way to check the engine's condition. Unfortunately you'll never know the condition of the engine until it blows.
Old Jul 29, 2003 | 08:37 PM
xfeastonarsex's Avatar
fire from MY tailpipe!
Just turn up the boost that will help even it out
Old Jul 29, 2003 | 08:55 PM
mizike's Avatar
Hey Chris,
When you bought the car did the guy say he rebuilt it before? If so, how many miles was that ago? Your compression should be fine man....don't think about it all the time. I've got 193,000 original miles on my car and it runs great! Your car should last you a long time, just make sure you change the oil every 1500 miles or so and check your plugs often and you should be fine man
my $0.02
Mike
Old Jul 29, 2003 | 09:00 PM
mizike's Avatar
if you want, maybe do the ATF trick....i found that made a difference.....also, start premixing!!
Old Jul 29, 2003 | 09:53 PM
Dan H's Avatar
Zoom Zoom Boom!
Was the engine tested cold or warm? Was it rebuilt recently? Was your battery fully charged?
These stuff can throw off "real" compression #'s. Unfortunately, a compression test will only tell about the apex seals, not the coolant or oil seals. So its tough to say how long it will last.
Old Jul 29, 2003 | 09:59 PM
n4ji's Avatar
SPQR
My friend with an FD premixes with, believe it or not, that "Marvel Magical Mystery Oil" and he says it's the best thing he's ever done to the car. He also put it in his lawnmower, thing cuts grass like there's no tomorrow now!
Old Jul 29, 2003 | 10:20 PM
I use that stuff sometimes. Does he put it in his oil too? I used it in my GFs MX6 and it seemed to work great. Never heard of running it in the oil of a rotary though.
Old Jul 29, 2003 | 10:24 PM
Oh and I did the ATF trick, but I don't think I put enough in because it didn't smoke all to hell like most people describe it. I'm going to do it again though soon and probably leave it in there a week or so.
n4ji's Avatar
SPQR
Nah, he uses Mobil 20W-50 for his oil. Thing runs so hot it's rediculous.
Old Jul 30, 2003 | 01:43 AM
MaTT_FoULk's Avatar
earning these was better
You shouldn't do the ATF trick unless your car is pretty damn flooded.
Old Jul 30, 2003 | 02:05 AM
vectorminds's Avatar
Where's My Fuel???
could prolly do the mmo trick though... that would prolly be a bit safer....
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
