What plugs do you run in your 20B?
Hunting Skylines
Just wandering what plugs you guys recommend. The ones that were in the Cosmo when I bought it are NGK's SD10A and SD11A marked L and T. Are these the factory specified plugs? I assume most are just running BUREQ's? What else?
You should use the following for normal Cosmo driving....
BUR6EQ.............Leading
BUR8EQ.............Trailing
If you want to give it a hard time regulary then go up a range to the same as the FD RX-7 (92-02)
BUR7EQ.............Leading
BUR9EQ.............Trailing
SD10 & SD11 are way too cold, foul up & give you grief for normal traffic conditions. Plus, they are a **** plug by comparison
You can get the 7/9 combo from a Mazda dealership. If you don't quote the correct part number they will try to sell you the platinum version at double the price.
Part#... N34318110 = Leading
Part#... N34218110 = Trailing
If you want the 6/8 combo, then you have to order them through an NGK spark plug stockest such as "Supercheap"
REgards
REgards
Trending Topics
alphawolff
Nov 17, 2015 05:57 PM
20B Forum
Aug 18, 2015 02:46 PM
