breaking a turbo motor in...
Old Jul 21, 2003 | 10:57 AM
GeTCrAzYKiD's Avatar
Zoom Zoom Boom
A friend of mine is breaking in a rebuilt turbo II motor w/ a bridge port. And my question is, how many miles is good untill its broken in. Reason for my question is we're running it at MOROSO sometime this week if it has enough miles. Thanks!
Old Jul 21, 2003 | 12:22 PM
tims's Avatar
a couple hours of use should be fine. most people recomend 500 miles of easy driving at varied rpm. are you drag racing or road racing? change the oil check all the belts and hose connections and have some fun.
Old Jul 21, 2003 | 01:03 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Not to hijack but i have a simiar question
I plan on building a highcomp turbo motor, its not together yeat (still collecting parts) but am worried about stressing the motor while breaking it in. Ive read that im suppoto keep the engine out of boost during inital break in. Now with my 9.7:1 rotors im worried im goign to be boosting at a low load and/or low rpm. Should i be worried? And if so how should i stop the engine from boosting? Large wastegate? Restrictive intake/exhaust? Combination of both?
thanks
Old Jul 21, 2003 | 05:32 PM
Zoom Zoom Boom
Well, its not only going to be for racing. Its also a daily driver. Its got about 400 on it now and I planned on taking it to MOROSO either wednesday or friday night. I considered friday nigth so that i could break in it farther. So I guess it should be fine by then. Thanks alot!
Old Jul 22, 2003 | 06:53 AM
ErnieT's Avatar
Living life 9 seconds at a time
If your doing a rebuild only, there's nothing to "break in". If the only thing new is your corner seals, apex seals, and side seals. Give it two heat cycles, change the oil and go race. I broke my new engine in with 28psi on the dyno as did Demetrios. Hell, he has over 180 dyno pulls and over 50 passes on the same engine that was never "broke in".
Old Jul 22, 2003 | 08:57 AM
So if i drive my car around for a week or so being nice to it i should be all set?
Old Jul 22, 2003 | 09:00 AM
tims's Avatar
ernie has the real life break in procedure. I have never done much more than run the engine to full temp, drain the oil, replace with new oil, check all connections, and then go racing. it is more important to make sure oil and water temps are up to operating levels before going onto the track.
Old Jul 22, 2003 | 05:38 PM
Zoom Zoom Boom
Thanks alot you guys..If i can i'll post up some slips..i might be going tomorrow! If anyone is going out there let me know..cell 7545813539 nextel 159*24962*4
cristoDathird
28
May 30, 2019 08:47 PM
PhillyFC
Aug 21, 2015 06:36 PM
